XtremeMarineInc Posted August 22, 2007 Share Posted August 22, 2007 The RH side (off-side for me , near side for you guys) bulkhead outrigger is completely a loss. I have another frame I picked up for free for parts that is exactly the same. Can I take the LH outrigger off, turn it around and use it? Or do they have slightly different specs, and different part numbers. It would save some time and money if I could just clean up my extra, flip it 180 degrees and weld on. Thanks. Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted August 22, 2007 Share Posted August 22, 2007 Well, the only specs involved are the dimensions. Measure it. If its the same, weld it on. Al. Quote Link to comment Share on other sites More sharing options...
OWL Posted August 22, 2007 Share Posted August 22, 2007 I think they are the same, Check the part numbers here :- Here Quote Link to comment Share on other sites More sharing options...
steve b Posted August 22, 2007 Share Posted August 22, 2007 Yep go for it , they are the same . IIRC the only handed bulkhead outriggers on series LR is 86"/88"/107" S1 cheers Steveb Quote Link to comment Share on other sites More sharing options...
XtremeMarineInc Posted August 23, 2007 Author Share Posted August 23, 2007 Thanks for the link, Owl. According to Bearmach's diagrams; the part number is the same for both sides on a II, IIa, or III 88" chassis. Appreciate it. This will save me some money on the chassis work. Quote Link to comment Share on other sites More sharing options...
