Shackleton Posted August 29, 2007 Share Posted August 29, 2007 On the N/S of my LT95 there's a cylindrical steel bar (roughly 1/2 or 3/4" diameter) coming through the casing, kinda midways along the box. It's got a hole cross drilled in it. It looks as though it could be turned if you gripped it. Anyone know what it is? I'm thought initially it might have been to do with mounting the hand brake on a LH drive RR but the why does it go into the casing... Quote Link to comment Share on other sites More sharing options...
Ruuman Posted August 29, 2007 Share Posted August 29, 2007 any chance of a picture, I'll have a look at mine and see what it could be Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 29, 2007 Share Posted August 29, 2007 On the other side has it got the High Low Lever ? If so its the shaft for the HL Lever, and is either RHD or LHD but the shaft does both Nige Quote Link to comment Share on other sites More sharing options...
nickm Posted August 30, 2007 Share Posted August 30, 2007 On the other side has it got the High Low Lever ?If so its the shaft for the HL Lever, and is either RHD or LHD but the shaft does both Nige isnt it the bar for moving the lever to the other side i.e for a left hooker Quote Link to comment Share on other sites More sharing options...
