jules Posted September 16, 2007 Share Posted September 16, 2007 I've been respaying the roof of a old S11 and I though it would be easyer to pop the back windows (quater lights I think there called) out instead of marsking them up. I removed the rubber inner strip and pushed the windows in, To easy spayed the whole roof But can't for the life of me get them back in Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted September 16, 2007 Share Posted September 16, 2007 Hi Have you got the special tool? if not you can try the rope trick using synthetic poly rope? i used 3 hands a couple of flat screwdrivers and lots of wd40 to get mine in Mike Quote Link to comment Share on other sites More sharing options...
jericho Posted September 16, 2007 Share Posted September 16, 2007 Washing-up liquid,and the handle of a tea spoon . High tech! Quote Link to comment Share on other sites More sharing options...
western Posted September 16, 2007 Share Posted September 16, 2007 soak thenm in hot water, [as hot as you can handle] it makes them more pliable & easier to refit, the locking strip should be on the inside. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 16, 2007 Share Posted September 16, 2007 I've got the "proper" tool to get the rubber filler strip in Jules. want to borrow it? PM me your address and i'll stick it in a jiffybag. Quote Link to comment Share on other sites More sharing options...
jules Posted September 17, 2007 Author Share Posted September 17, 2007 I've got the "proper" tool to get the rubber filler strip in Jules. want to borrow it?PM me your address and i'll stick it in a jiffybag. That would be grate I good give it back to you at sodbury. Thanks Ive PM'd you Quote Link to comment Share on other sites More sharing options...
jameslwt Posted September 17, 2007 Share Posted September 17, 2007 That would be grate I good give it back to you at sodbury. Thanks Ive PM'd you Jules If you get stuck give me a ring as have done it loads of times on my 110 and as you know am just around the corner from you. 07736 724229 James Quote Link to comment Share on other sites More sharing options...
jules Posted September 17, 2007 Author Share Posted September 17, 2007 JulesIf you get stuck give me a ring as have done it loads of times on my 110 and as you know am just around the corner from you. 07736 724229 James I might take you up on that offer over the weekend Thanks Quote Link to comment Share on other sites More sharing options...
