pigster Posted October 31, 2005 Share Posted October 31, 2005 I know its not a LR - but I do own one, and I crashed Les's a couple of weeks ago. I sorta hope someone will know something about normal cars so here goes... The Vw forum seems to be as active as a frozen dead thing. the issue Anyway - as the topic says, My electric windows are doing really weird things on me and I would like some one to tell me how to fix it. The vehicle is a Passat and its a '94 1z engine (1.9tdi - 90bhp) estate. right thats the main details you may require. so here goes... The windows are shot, the front passenger doesn't like moving via its own door switch (but will move intermitant via drivers door) and if you do get the thing to move down it will close itself shortly after. The drivers door is doing pretty much nothing at all - it doesn't open (even via the keys when locking or unlocking) However the back windows work nicely (be it via the dash switches or the door electrics) I don't think there is anything else happening that I need to mention. any ideas anyone? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
siggy Posted October 31, 2005 Share Posted October 31, 2005 I would guess your Switches are sha99ed replace them. circuitry is easy voltage one way windows up reverse voltage windows down (Basically) Quote Link to comment Share on other sites More sharing options...
pigster Posted October 31, 2005 Author Share Posted October 31, 2005 so do I need to replace both the front switches as the rear seem to work. You say its simple circuitry... so I assume theres no brain (electrical) it is just power for up window, power for down window... simple as.. In which case I could bodge it to see if the switches are knackered or not by wireing in some cheap flick switch and seeing what happened.. and then go from there... ok - - thank you.. Just needed someone to back up my thoughts/hopes.. Quote Link to comment Share on other sites More sharing options...
siggy Posted October 31, 2005 Share Posted October 31, 2005 I'd say yes if you can identify which wire does what thet you can use a shorting strap to mimic the switch power to down term window should go down power to up term window go up Quote Link to comment Share on other sites More sharing options...
Dale Simpkins Posted October 31, 2005 Share Posted October 31, 2005 If you have no joy with what's already been suggested, you could try this forum http://www.uk-mkivs.net It's a active UK VW Forum, and covers all the water cooled VAG vehicles. I've got useful info from it in the past. I'm afraid I can't offer any advice as I only know about old skool air cooled VWs. Quote Link to comment Share on other sites More sharing options...
cols110 Posted October 31, 2005 Share Posted October 31, 2005 We have/had a similar problem with our MK3 golf, now the it wont work at all. When we hit the switch you can hear the motor clicking and it also warms up when you hold the switch, so power is getting to the motor, but it looks as though the motor is shagged. I did a bit of googling and found that is a common problem on the VWs for the motors to plop em`selves. The main problem now is the window is stuck in the up position, the window has to come out to remove the motor/regulator so replacing the motor is easier said than done. My advice is if you can still open your window make sure you fix it before it totally fails. If you want to check out your switch is a pretty easy to remove, you can also strip it down pretty easiley as well, been there done that, but to no avail. Let us know how you get on. Quote Link to comment Share on other sites More sharing options...
siggy Posted October 31, 2005 Share Posted October 31, 2005 On the PUG I owned it had electric windows and when they started going faulty I managed to get a winder that enabled to get the windows down in an emergancy pop cap covering motor and place over and wind in the normal manner! Quote Link to comment Share on other sites More sharing options...
cols110 Posted October 31, 2005 Share Posted October 31, 2005 Very interesting, thanks for that, I`ll have to give it a go. Quote Link to comment Share on other sites More sharing options...
pigster Posted November 1, 2005 Author Share Posted November 1, 2005 excellent stuff .. thanks very much for the hints tips.. I shall get working on the switches first and then go for the motors.. I have noticed an onnoying clicking noise from within the door mainly the passenger side, the windows winds up and then you get a clicking noise which stops after a few seconds.. cheers again.. I shall tell you how it went once I have done the possible fixes.. Quote Link to comment Share on other sites More sharing options...
