landybear Posted October 12, 2007 Share Posted October 12, 2007 Hi all, Posting for a mate whos vehicle it is. The airbag light doesnt go out on the dash - what can be causing this and how can it be solved?? other than disconnecting it!! Sorry for being a bit vague Cheers in advance Quote Link to comment Share on other sites More sharing options...
Ivan Posted October 12, 2007 Share Posted October 12, 2007 Sounds like there is a problem with the SRS. Only cure is to plug it in to testbook and find out what's wrong. Ivan Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 12, 2007 Share Posted October 12, 2007 The most likely cause is failure of the rotary coupler cassette in the steering wheel, this is not an uncommon problem and is very expensive to fix i.e. a couple of hundred pounds for the part. It is quite easy to change one though, half an hour should see the job done just remember to use the proper procedures as per the workshop manual just to make sure you don't get a face full of airbag. Cheap nylon jumpers are a bad choice of clothing for example You will still need a diagnostic computer to verify this though, and once it has been repaired you will need to plug it in again to clear the fault code, SRS faults don't self-clear after x number of drive cycles like some other systems. Quote Link to comment Share on other sites More sharing options...
landybear Posted October 13, 2007 Author Share Posted October 13, 2007 Cheers guys very helpful as usual. I will let him know. Quote Link to comment Share on other sites More sharing options...
