s2hotdog Posted October 14, 2007 Share Posted October 14, 2007 I have just brought a very good 12 V compressor that connects directly to battery terminals with jump lead type connnectors that works a treat. For ease of use I wanted to convert it to a ciggarette type socket, but having brought one (cheap one to be fair) it dos'nt look half man enough the wires on compressor are 2-3 mm approx and it has an inline fuse - so is there another way to achive ? rather than taking the seat out every time I want to use. It would appear that I have to solder the wires to the spring type metal and to central button on the ciggeratte socket Many thanks for any imput. Steve Quote Link to comment Share on other sites More sharing options...
BennyB Posted October 14, 2007 Share Posted October 14, 2007 One way of doing this is with a quick connect plug wired to the battery, then putting the same plug on the compressor (such as Anderson plugs). This way you could also use other item with larger electrical draw (or use jump leads). I don't think it would be a very good adea to try and run the compressor off your ciggeratte socket (all i think you would do is blow fuse's). Has the compressor got an inline fuse in it? What size is it? Quote Link to comment Share on other sites More sharing options...
MogLite Posted October 14, 2007 Share Posted October 14, 2007 My T-max double compressor takes 30amps - measured with a clamp meter. The spec says it takes up to 70amps, but mine hasn't blown any 30amp fuses yet. No way are you going to get that kind of current through a ciggy lighter. Andy Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 14, 2007 Share Posted October 14, 2007 DO NOT use a cigarette lighter, it'll melt or in extreme circumstances catch fire, either way, it's really not a good idea. Even if you were to make a suitable plug, the socket and vehicle wiring are not up to that sort of load. if you're talking 30-70A, your only real option, as has been mentioned, is something like an anderson connector wired direct to the battery. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 14, 2007 Share Posted October 14, 2007 It's almost impossible to find a cig lighter that will supply more than 10A sustained without melting. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted October 14, 2007 Author Share Posted October 14, 2007 Use tha battery connections then untill I get an anderson connection What I thought really Thanks for the replies all Steve Quote Link to comment Share on other sites More sharing options...
nas90 Posted October 14, 2007 Share Posted October 14, 2007 I have just brought a very good 12 V compressor that connects directly to battery terminals with jump lead type connnectors that works a treat.For ease of use I wanted to convert it to a ciggarette type socket, but having brought one (cheap one to be fair) it dos'nt look half man enough the wires on compressor are 2-3 mm approx and it has an inline fuse - so is there another way to achive ? rather than taking the seat out every time I want to use. It would appear that I have to solder the wires to the spring type metal and to central button on the ciggeratte socket Many thanks for any imput. Steve Talk to Simon R, buy a X-Jump with an extra plug. Then you can jump start vehicles or run your compressor, plenty of scope for current flow in those jobbies Quote Link to comment Share on other sites More sharing options...
