DaveJ Posted November 22, 2007 Share Posted November 22, 2007 Hello all, I am just about to start a rebuild of my 300 tdie and was wondering about the bottom end gaskets. Should I get the full paper gasket set or use liquid gasket like silicon instead. I have had more success with sealing and less failures with silicon sealant before on water pumps etc. What is the consensus here? Cheers DaveJ Quote Link to comment Share on other sites More sharing options...
keithjh Posted November 22, 2007 Share Posted November 22, 2007 Hello all,I am just about to start a rebuild of my 300 tdie and was wondering about the bottom end gaskets. Should I get the full paper gasket set or use liquid gasket like silicon instead. I have had more success with sealing and less failures with silicon sealant before on water pumps etc. What is the consensus here? Cheers DaveJ I have always used the standard gaskets and never had a problem, only use the "instant Gasket" Silicon if i have to. Regards Keith Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 22, 2007 Share Posted November 22, 2007 The sump gasket should be RTV sealant anyway. If you need more than just the sump gasket, then there is a bottom end set that comes with cam, crank, and timing cover seals. Les. Quote Link to comment Share on other sites More sharing options...
DaveJ Posted November 22, 2007 Author Share Posted November 22, 2007 Thanks. Will probably order gasket set then from Paddocks as I have a bare block sitting on my bench desperately awaiting reassembly. Cheers Dave Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted November 23, 2007 Share Posted November 23, 2007 I use both the gasket and RTV on my rebuilds and that seems to work well. ps trick with the sump gasket is to let the RTV cure for about 30 mins before bolting it up. And then don't fill it with oil for a day if you have the time. This results in a very non-Landrover lack of leaks Quote Link to comment Share on other sites More sharing options...
DaveJ Posted November 23, 2007 Author Share Posted November 23, 2007 I use both the gasket and RTV on my rebuilds and that seems to work well. ps trick with the sump gasket is to let the RTV cure for about 30 mins before bolting it up. And then don't fill it with oil for a day if you have the time. This results in a very non-Landrover lack of leaks Cheers Jim, think I will have plenty of time! DaveJ Quote Link to comment Share on other sites More sharing options...
paintman Posted November 23, 2007 Share Posted November 23, 2007 ps trick with the sump gasket is to let the RTV cure for about 30 mins before bolting it up. And then don't fill it with oil for a day if you have the time. This results in a very non-Landrover lack of leaks A Land Rover without oil leaks Heresy! Quote Link to comment Share on other sites More sharing options...
