Dave Disco Posted November 22, 2007 Share Posted November 22, 2007 It must be catching! Mine is a '92 4 door with aircon. Big problem is the O/S rear spring seat on the chassis is badly rotted and no one seams to supply a replacement! I've been told a Def 90 one can be adapted, anyone been there with this? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 22, 2007 Share Posted November 22, 2007 Apart from 110/130 rears most coiler spring mounts are very similar if not the same because the springs are the same. Welcome, by the way Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted November 22, 2007 Share Posted November 22, 2007 If you can get a 90 one it will be fine. I made my own out of a few bits of 5mm plate. Really very simple. If you are confident enough to weld it on then you will have NO problems knocking one up in a few minutes Quote Link to comment Share on other sites More sharing options...
russ3120 Posted November 22, 2007 Share Posted November 22, 2007 I made my own to, extremely simple job to do. Here is a link to a how to do it by Les http://forums.lr4x4.com/index.php?showtopic=19718 Russ Quote Link to comment Share on other sites More sharing options...
Dave Disco Posted November 23, 2007 Author Share Posted November 23, 2007 It's the one on the chassis, not the axle mounting point. I've done an axle mount before and as you say it's dead easy Quote Link to comment Share on other sites More sharing options...
