red90 driver Posted November 22, 2007 Share Posted November 22, 2007 I think (as the topic title says) we may have dropped a minor boo boo.... Just acquired a new RD57 arb for the 90 from fleabay. (As in already in my sweaty mitts) However, I think that it will not fit into the 300 rear axle due to the larger flange diameter??? True / false ??? So, my question is, will the RD57 fit into a 300 rear axle without the use of a large press? Quote Link to comment Share on other sites More sharing options...
white90 Posted November 22, 2007 Share Posted November 22, 2007 I think RD57 is for a P38 diff Quote Link to comment Share on other sites More sharing options...
white90 Posted November 22, 2007 Share Posted November 22, 2007 yep as I thought time to sell it on Quote Link to comment Share on other sites More sharing options...
red90 driver Posted November 22, 2007 Author Share Posted November 22, 2007 yep as I thoughttime to sell it on Bugger. anyone want a brand new RD57??? Quote Link to comment Share on other sites More sharing options...
white90 Posted November 22, 2007 Share Posted November 22, 2007 anyone with a later 110 may also be interested Quote Link to comment Share on other sites More sharing options...
red90 driver Posted November 22, 2007 Author Share Posted November 22, 2007 And P38 axles won't fit onto a 90 either I suppose????? Quote Link to comment Share on other sites More sharing options...
SiWhite Posted November 22, 2007 Share Posted November 22, 2007 Don't think so - diff is on the wrong side IIRC...... Quote Link to comment Share on other sites More sharing options...
white90 Posted November 22, 2007 Share Posted November 22, 2007 there is one on our TD5 110 mounts are all the same as the 90 Quote Link to comment Share on other sites More sharing options...
white90 Posted November 22, 2007 Share Posted November 22, 2007 this is a P38 style rear axle on the 110 diff on same side and No I don't want it thanks the sheet above says this axle is fitted 2002> Quote Link to comment Share on other sites More sharing options...
red90 driver Posted November 22, 2007 Author Share Posted November 22, 2007 they will fit I'm surethere is one on our TD5 110 mounts are all the same Is it that the 8.05" flange will not go into the axle casing even if you use a p38 3rd member? Or is it just impossible to fit regardless? (Told you I'm having a blonde moment.....) Quote Link to comment Share on other sites More sharing options...
white90 Posted November 22, 2007 Share Posted November 22, 2007 I'm not totally sure but the casing on the 110 axle is different to the 90 one. Quote Link to comment Share on other sites More sharing options...
red90 driver Posted November 22, 2007 Author Share Posted November 22, 2007 Thanks for the input. I would guess that we are truly up the creek and we will just sell the diff and keep looking. B) Quote Link to comment Share on other sites More sharing options...
ciderman Posted November 22, 2007 Share Posted November 22, 2007 we will just sell the diff and keep looking. B) For an RD 56 maybee? Quote Link to comment Share on other sites More sharing options...
Lewis Posted November 23, 2007 Share Posted November 23, 2007 IIRC Divster is using a Disco2/P38 type diff (the one your locker fits) is a modified standard axle case in the rear of his trayback. Also a friends brother has the P38 centre section welded into a front axle case to give a four pin diff. So yes, it can be done, and no P38 axles will not bolt on, but as white90 correctly says a recent 110 rear will, which is handy because they go for peanuts on ebay Quote Link to comment Share on other sites More sharing options...
techtone Posted November 23, 2007 Share Posted November 23, 2007 Your easier just getting a late 110 rear axle and fitting that. This is the none salisbury one ie does not have a large tin rear cover, it looks almost the same as a standard 90 apart from the diff pan bowel has no shaping around the crown wheel. Either way its not the end of the world you can always sell it on! not to me though, I already have one in a wolf axle! Quote Link to comment Share on other sites More sharing options...
red90 driver Posted November 23, 2007 Author Share Posted November 23, 2007 Certainly gives me something to work with now. Quote Link to comment Share on other sites More sharing options...
