pinny Posted November 24, 2007 Share Posted November 24, 2007 im looking to change my tyres from 205/16 to 225/16 the front are wearing oviously quicker than the rears has any one put 225 on the front and still had 205 on the rear oviously as the rears wear ill change them to 225 any thoughts on this cheers chris Quote Link to comment Share on other sites More sharing options...
RRX Posted November 24, 2007 Share Posted November 24, 2007 You should change all the tyres to be the same size. once changed rotate them around the car every few thousand miles and this will wear them out all about the same. putting different sized tyres on front and rear will cause allsort of odd handling characteristics and if you locked the centre diff you will have 2 wheels turning at a different rate to the other 2 Quote Link to comment Share on other sites More sharing options...
pinny Posted November 24, 2007 Author Share Posted November 24, 2007 You should change all the tyres to be the same size. once changed rotate them around the car every few thousand miles and this will wear them out all about the same. putting different sized tyres on front and rear will cause allsort of odd handling characteristics and if you locked the centre diff you will have 2 wheels turning at a different rate to the other 2 thats what i thought would happen ill look into changing them all cheers chris Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 24, 2007 Share Posted November 24, 2007 You don't say what aspect ratio you'd be fitting - 205R16's are 80% (if memory serves, so really 205/80R16) so your 255's would need to be 255/65R16 to be even close to the same diameter. To calculate old Vs new size, have a look 1/3 the way down this page for a calculator. Even then, assuming you can match the height, odd widths will look strange. Plus, in matching the height of the 205's, you're missing out on the chance to fit taller tyres and increase ground clearance. I'd bit the bullet and upgrade the whole set rather than having odd tyres. Quote Link to comment Share on other sites More sharing options...
