geoffbeaumont Posted December 10, 2007 Share Posted December 10, 2007 Came across a heated fuel filter element for the discovery () when ordering bits. The only vaguely decent description I could find was on AULRO - nothing in the Hayneous manual. On the face of it it seems like a good idea if you're running biodiesel (and therefore are prone to the same problems diesels in colder climates have). Does anyone have one of these heated filters? Are they any good, and what parts would I need to convert mine? I can't find any parts numbers for the actual heater plug, only the filter. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 10, 2007 Share Posted December 10, 2007 I thought the original diesel RR's had a heated filter? may be the same unit I would certainly like one for the **** fuel we use here, it would help a lot... Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted December 10, 2007 Author Share Posted December 10, 2007 I thought the original diesel RR's had a heated filter? may be the same unitI would certainly like one for the **** fuel we use here, it would help a lot... Same part number for the filter, so I'd guess exactly the same unit. Quote Link to comment Share on other sites More sharing options...
lynall Posted December 10, 2007 Share Posted December 10, 2007 Check out your local scrappy for any vauxhall diesels specifically the 1.7 vauxhall and isuzi lumps as they had heated fuel filters which i am pretty certian is the same fitting as tdi filter. Lynall Quote Link to comment Share on other sites More sharing options...
