white90 Posted December 19, 2007 Share Posted December 19, 2007 Are the brown contour lines in feet or metres Quote Link to comment Share on other sites More sharing options...
will_warne Posted December 19, 2007 Share Posted December 19, 2007 OS = metres Quote Link to comment Share on other sites More sharing options...
white90 Posted December 19, 2007 Author Share Posted December 19, 2007 The index on MM says height in feet. I'll go and look again Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted December 19, 2007 Share Posted December 19, 2007 Contour lines are at 10 metre vertical intervals, and spot heights are at the nearest metre above mean sea level. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 19, 2007 Author Share Posted December 19, 2007 Thanks very much. Quote Link to comment Share on other sites More sharing options...
SiWhite Posted December 19, 2007 Share Posted December 19, 2007 Yup, metres. Interesting bit of contour lines trivia - they are invisible when viewed under red light. This is the stock excuse when asked why the Army walk up so many hills at night...... Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted December 19, 2007 Share Posted December 19, 2007 But you can get red light readable maps so you can see the contours. But we'll still keep walking up hills cos it's character building stuff Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted December 19, 2007 Share Posted December 19, 2007 Tony, Its because you have MM set to statue (Miles), so it measures in Miles & feet………. However, the OS maps are metric and the contours will be metres, but if you do a 3D or fly through then MM will convert your height to feet, but this info is gained form a separate database…….. If you have other maps than OS (for example, I have a load of IGN French maps) then you can always check what the map base datum’s are by going to ‘Map – Edit Map Properties’ Ian Quote Link to comment Share on other sites More sharing options...
JST Posted December 19, 2007 Share Posted December 19, 2007 Yup, metres.Interesting bit of contour lines trivia - they are invisible when viewed under red light. This is the stock excuse when asked why the Army walk up so many hills at night...... walk i thought they were meant to run up them? 10m Ci on 1:50k 5m CI on 1:25k PS - they arent painted on the ground either...... Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted December 19, 2007 Share Posted December 19, 2007 PS - they arent painted on the ground either...... Quote Link to comment Share on other sites More sharing options...
Paul Posted December 19, 2007 Share Posted December 19, 2007 Are the brown contour lines in feet or metres Hey Tony I recognise that blasted Pit Lane that the nav thingy on the Jag kept trying to send us down last year. Paul Quote Link to comment Share on other sites More sharing options...
white90 Posted December 19, 2007 Author Share Posted December 19, 2007 Paul you'd join a long list of victims of Pit Lane AA van crashed-winched out Wessex water van and trailer with mini digger-towed out Sainsbury home delivery crashed-towed out Tom Tom catches lots of people out there blindly following it although the signs say unsuitable for motor vehicles Quote Link to comment Share on other sites More sharing options...
