stripy Posted January 1, 2008 Share Posted January 1, 2008 has les or anyone done a nice "how to" on taking out the headlineing please i did do a search, but i'm not sure i done it right , i couldent find diddly cheers john Quote Link to comment Share on other sites More sharing options...
russ3120 Posted January 1, 2008 Share Posted January 1, 2008 has les or anyone done a nice "how to" on taking out the headlineing pleasei did do a search, but i'm not sure i done it right , i couldent find diddly cheers john why do you need to remove the headlining? you can remove your sunroof without taking out the headlining Quote Link to comment Share on other sites More sharing options...
stripy Posted January 1, 2008 Author Share Posted January 1, 2008 iv'e been told that they leak around the where the plastic tube fits for the drain, the only way to get at it is with the headlineing off "apparently" Quote Link to comment Share on other sites More sharing options...
munkymush Posted January 1, 2008 Share Posted January 1, 2008 check this article its got everything on repairing sunroof leaks+headling removal ..glenn http://stbernardtrust.bravehost.com/sunroof.html Quote Link to comment Share on other sites More sharing options...
Guy H Posted January 1, 2008 Share Posted January 1, 2008 Or this one http://www.muckytruckin.co.uk/pages/techni...f/discoroof.asp I used that one and it worked a treat. FWIW neither of my sunroofs leaked at the drains, they both leaked through the sunroof - roof seal (OEM is a bit of draught seal type stuff) goes hard & won't seal, water then gets in and dripped through the screw heads. Most likely once you've got the lining down you'll exactly where the problem is. Lining is surprisingly easy really, remember the interior light wires & stuff & don't worry about bending it, it springs back and the creases disappear. Getting it back in is much easier with two, but it can be done by yourself with a bit of swearing !! Whilst the lining's out check the alpine window seals and the roof to side seal esp at the rear quarters. Quote Link to comment Share on other sites More sharing options...
stripy Posted January 2, 2008 Author Share Posted January 2, 2008 thanks for the replys guy's headlineing and sunroofs now out, awaiting me to clean, mastic, and refit B) Quote Link to comment Share on other sites More sharing options...
enduro1972uk Posted January 18, 2008 Share Posted January 18, 2008 How long did it take to get the headlining out? Mine is in need of an inspection shortly. I did a temerary fix but does need doing correctly. Quote Link to comment Share on other sites More sharing options...
stripy Posted January 18, 2008 Author Share Posted January 18, 2008 hi enduro to get the headlining out will take an hour max, to get the sunroofs out cleand and resealed will take another couple of hours. i found it a realy stright forward & easy job to do, plus now i know everything is sealed and the overflow pipes clear and clean, it's well worth doing. if you put by a day to do it that would be plenty, with time for tea & cake to. cheers john Quote Link to comment Share on other sites More sharing options...
spud murphy Posted January 18, 2008 Share Posted January 18, 2008 Good links there chaps, looks like a to do job when the weather clears! Does anybody know if the manual type sunroofs are the same footprint as the electric piles of tripe that are fitted to my 300 ES?. If so I think a change is in the offing. Sorry to hijack the thread, any answers greatly appreciated. Cheers John Quote Link to comment Share on other sites More sharing options...
stripy Posted January 18, 2008 Author Share Posted January 18, 2008 hey spud mine is a manuel sunroof but it has all the plugs & wires for an eleccy one, so i would think you could swop to manuel Quote Link to comment Share on other sites More sharing options...
spud murphy Posted January 18, 2008 Share Posted January 18, 2008 Don't want a swop do you stripy??? Quote Link to comment Share on other sites More sharing options...
stripy Posted January 18, 2008 Author Share Posted January 18, 2008 let me think.......................er no Quote Link to comment Share on other sites More sharing options...
