jason_landy99 Posted January 9, 2008 Share Posted January 9, 2008 I am playing with the idea of cutting my hard top down half way and move the door back. Has any one done this to their 90? If so any tips on doing it? Edited for legibility by Mog. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 9, 2008 Share Posted January 9, 2008 What you're talking about is often called a 'king cab' after the US style cab on a lot of trucks. You'll have to do something about making/adding a new bulkhead, either using the old rear door, or another bulkhead etc. a lot of people use a combination of truck cab and hard top bits. 'The ultimate' is to cut down a 110 double cab roof, but they're stupidly expensive to get hold of - Ask Will Warne. Quote Link to comment Share on other sites More sharing options...
JST Posted January 9, 2008 Share Posted January 9, 2008 Si White did similar may be worth a PM Quote Link to comment Share on other sites More sharing options...
treebloke Posted January 9, 2008 Share Posted January 9, 2008 I have done two now and there loads about, everyone a bit different, if you PM me your e mail I can send you some pics. There are several ways to do it depends on what materials you have to start with and what finish you want. Some have the top half of a pick up door which are hard to come by, especially the hinges. Some simply go for the truck cab top with sliding windows. Quote Link to comment Share on other sites More sharing options...
JST Posted January 9, 2008 Share Posted January 9, 2008 i replied thinking i know loads who have done that then had a mind fart - yep Bob is one, plus Si, plus Les Brock to name a few Quote Link to comment Share on other sites More sharing options...
muddy Posted January 9, 2008 Share Posted January 9, 2008 north off road are doing a fiberglass rearroof curve so that ytou attach it to a chopped down hardtop and it fits a normal truckcab back, so if done right looks very proffesional. Will. Quote Link to comment Share on other sites More sharing options...
treebloke Posted January 10, 2008 Share Posted January 10, 2008 Jason I e mailed you some pics but for some reason they did not go?. Quote Link to comment Share on other sites More sharing options...
lard Posted January 10, 2008 Share Posted January 10, 2008 just bought a curved roof myself nice piece of kit just need a dry day to fit it , speak to shaun (north off road) very helpful to talk to!!! Quote Link to comment Share on other sites More sharing options...
ciderman Posted January 10, 2008 Share Posted January 10, 2008 just bought a curved roof myself nice piece of kit just need a dry day to fit it , speak to shaun (north off road) very helpful to talk to!!! I thought you already had a curvred roof , or was it a flat one ?? Quote Link to comment Share on other sites More sharing options...
lard Posted January 10, 2008 Share Posted January 10, 2008 I thought you already had a curvred roof , or was it a flat one ?? Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 10, 2008 Share Posted January 10, 2008 Spotted this in Aus a couple of years back. Looked like a factory job. Quote Link to comment Share on other sites More sharing options...
John110 Posted January 11, 2008 Share Posted January 11, 2008 @Treebloke could you post a few more pic's of yours? I'm toying with the idea of using a 90 roof sides and rear door to extend the cab on my 110 pic up by about 3 foot. Or if anyone could shec some light on this it would be much appriciated. Cheers John Quote Link to comment Share on other sites More sharing options...
treebloke Posted January 11, 2008 Share Posted January 11, 2008 Thought I would put a few more pics of cutting the roof down to king cab size, just wish I had taken a few more now. You will need to disconnect the rear roof light and wiring together with the washer bottle pipe. We used the origional seem that joins the roof together, cut the top away from the bottom, you can afford to damage the rear/top section because theres more there than what you need. We had some expensive wooden steps available. Once the tops off you need to cut the sides down, this was probably the trickiest bit, need to get your sums right. Measure twice, cut once. We had a galv Z bar lying around which was just the right fit to carry the rear and corner sections. We filled in the lower half of the back with marine ply then lined the outside with chequer plate Because I managed to find an upper top half of a rear door including hinges, I cut my origional rear door down and put it back on. It also carried the spare wheel for a while. This was before I had the roll cage fitted, I dont bother with this method now, the spare wheel sits in the roll cage behind the rear window and on top of the rear winch. You can hardly see the join now. Quote Link to comment Share on other sites More sharing options...
Night Train Posted January 11, 2008 Share Posted January 11, 2008 Nice job there, very well executed. A friend of mine did something very similar in 1990 with a S3 109 pick up with an 88 hard top on it. Quite effective as an early crew cab. Quote Link to comment Share on other sites More sharing options...
John110 Posted January 12, 2008 Share Posted January 12, 2008 Excellent, I'll do a bit more research before a take a grinder to it Thanks for the pics. Cheers John Quote Link to comment Share on other sites More sharing options...
