nickm Posted January 17, 2008 Share Posted January 17, 2008 200tdi disco any ideas what would produce loads and loads of white smoke guessing its probably the turbo air filter is fine and the breather on top of the head is new oil looks good with no water/white gunk on the filler cap used to start on the button but is now taking a lot longer to fire up Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 17, 2008 Share Posted January 17, 2008 When? all the time? on starting? white smoke is probably steam. unburt, badly/partially atomised fuel shows as grey smoke, as apposed to excess fuel, which is black smoke. Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted January 17, 2008 Share Posted January 17, 2008 200tdi discoany ideas what would produce loads and loads of white smoke guessing its probably the turbo air filter is fine and the breather on top of the head is new oil looks good with no water/white gunk on the filler cap last time i saw loads of white smoke from a deisel engine it smelt of fuel and was very white not blueish it was woodruff key on crank breaking up from pully being slightly loose and the timing [pump] being retarted as a result it wasent obviose because the lower timing mark was on the pully good luck merrick Quote Link to comment Share on other sites More sharing options...
Tonk Posted January 17, 2008 Share Posted January 17, 2008 white smoke is normally head gasket Quote Link to comment Share on other sites More sharing options...
nickm Posted January 17, 2008 Author Share Posted January 17, 2008 theres loads when i start it and loads and loads more when i rev it was going to change the turbo over incase thats playing up I have recently changed the cam belt but i think it was smoking b4 I changed it how could i check would i need to remove the timing cover ? Quote Link to comment Share on other sites More sharing options...
alfredenewman Posted January 17, 2008 Share Posted January 17, 2008 if you have just chaged belts iwill bet you a bacn roll and tea [collected next meet ] that the pump timing is retarded are we on Quote Link to comment Share on other sites More sharing options...
reads90 Posted January 17, 2008 Share Posted January 17, 2008 As tonk says head gasket (remeber when mine went Tonk ) If you tdi has done anywhere near 100,000 - 110,000 miles then tend to go at that anyway But on a diesel white smoke means water . and the longer time to start also points to head gasket as the compression in the engine is not as good as it should be , Quote Link to comment Share on other sites More sharing options...
nickm Posted January 17, 2008 Author Share Posted January 17, 2008 wouldnt it use water and get hot if the head gasket has gone will strip it at the weekend and take a look can also make sure it's timed correctly at the same time knew i should of washed the engine b4 putting it in the worshop Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted January 17, 2008 Share Posted January 17, 2008 But on a diesel white smoke means water . Or incorrectly burnt fuel and the longer time to start also points to head gasket as the compression in the engine is not as good as it should be , or incorrect timing. This all depends on whether the 'white' smoke is steam or diesel - it could be either. I wouldn't suspect the turbo at all, not a bit. If it's producing "loads and loads" of steam, It'd be using water. What does it smell like? Quote Link to comment Share on other sites More sharing options...
nickm Posted January 17, 2008 Author Share Posted January 17, 2008 What does it smell like? guessing it smells of fuel diesel cooking oil redex does sting the eyes a bit Quote Link to comment Share on other sites More sharing options...
Tonk Posted January 17, 2008 Share Posted January 17, 2008 As tonk says head gasket (remeber when mine went Tonk ) A34 i believe, on the way to a comp, they always break down at the most convenient times Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted January 17, 2008 Share Posted January 17, 2008 If its not using water, i would say the timing in 1/2 -1 tooth out in the pump easy fix, but a pain if you just put the new one on. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted January 17, 2008 Share Posted January 17, 2008 What does it smell like?guessing it smells of fuel diesel cooking oil redex does sting the eyes a bit I'm using BioDiesel in mine at the moment. When it's cold it smokes abit on start up and then when you rev it. After a couple of minutes it stops. So in my case it's unburnt fuel and not water. People always assume the worst. Check the timing as a starting point and then progress from there. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted January 17, 2008 Share Posted January 17, 2008 diesel cooking oil redex May be your problem. Veggy in high enough concentration will not atomise correctly in a cold engine = white smoke. Will also occur on a hot engine if your timing is retarded or the injectors are worn. If so, then watch out....unburnt veggy=piston ring coking & sump oil polymersiation. That said, LR TDi's seem to be a bit more robust that some DI engines, possibly because of the swirl chamber set into the top of the piston containing the charge...maybe... Quote Link to comment Share on other sites More sharing options...
nickm Posted January 17, 2008 Author Share Posted January 17, 2008 May be your problem. Veggy in high enough concentration will not atomise correctly in a cold engine = white smoke.Will also occur on a hot engine if your timing is retarded or the injectors are worn. If so, then watch out....unburnt veggy=piston ring coking & sump oil polymersiation. That said, LR TDi's seem to be a bit more robust that some DI engines, possibly because of the swirl chamber set into the top of the piston containing the charge...maybe... mmm i was thinking that aswell gonna drain the tank on sun and change the fuel filter Quote Link to comment Share on other sites More sharing options...
