muzaz Posted January 23, 2008 Share Posted January 23, 2008 Hi, I bought a 200tdi injector pump off ebay, and unfortuately it came without the hub, pulley and retainer. Its a nightmare trying to find one, anyone knows the part no for the hub etc, I'm not even sure of what exactly goes on the drive shaft! chris Quote Link to comment Share on other sites More sharing options...
western Posted January 27, 2008 Share Posted January 27, 2008 pulley is ERR667, Retainer plate is ERR359 & the hub that shouldn't be removed is part of the pump assembly, you'll most likely have to visit a Bosch diesel specialist to obtain that as LR doesn't list it in the parts catologue. bosch pump in tech archive Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 27, 2008 Share Posted January 27, 2008 I don't suppose the 2.5 TD/NA pump sprockets are the same? I have two here. Les. Quote Link to comment Share on other sites More sharing options...
western Posted January 27, 2008 Share Posted January 27, 2008 I don't suppose the 2.5 TD/NA pump sprockets are the same? I have two here.Les. Different part number ETC5717 & doesn't have the 3 bolts & retainer plate. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted January 27, 2008 Share Posted January 27, 2008 So, if ya buy a 2nd hand injector pump, how do you get it accurately timed up ? I'm just getting mine rebuild by a bosch specialist, so it will come back 'lock up'. Are they easy to time ? Quote Link to comment Share on other sites More sharing options...
western Posted January 27, 2008 Share Posted January 27, 2008 Refer to this thread 200Tdi timing belt change go from the 12th photo & write up above it onwards. Quote Link to comment Share on other sites More sharing options...
muzaz Posted January 28, 2008 Author Share Posted January 28, 2008 Thanks for your replies... I've sourced the pump sprocket... What remains are the pump hub and retainers, hopefully I should be getting these shortly as there's no part no. for the hub, so i had to rely on photos marking the parts needed. Hope that in the end I'll recieve the right parts! I dont know why some ppl sell them without that hub! Quote Link to comment Share on other sites More sharing options...
muzaz Posted February 22, 2008 Author Share Posted February 22, 2008 an update at last! Took the pump at a diesel specilalist to test it and see if it works ok... he said that the hub shouldnt be a problem bec its interchangable with ford models, but it needs to be correctly set on the shaft, the keyway is not used. While at it told him to open the pump up check the internals and re kit it... total cost is 70Eur... if he finds nothing broken!! Gave him the injectors as well to test and clean them Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 22, 2008 Share Posted February 22, 2008 70 Euros is cheap! I had my pump checked and it cost me £120 Les. Quote Link to comment Share on other sites More sharing options...
muzaz Posted February 22, 2008 Author Share Posted February 22, 2008 well labour cost here is still lowish compared to the uk... but to buy something like a second hand pump will cost you something like 300Eur, or a 200tdi at 1600Eur... but £120 for servicing a pump is a bit excessive Imo, I bought the pump for £30 off ebay, thats what I call a deal...that is if the guy tells me its ok when I go to pick it up next wednesday!! Quote Link to comment Share on other sites More sharing options...
