DrRob Posted January 29, 2008 Share Posted January 29, 2008 Any ideas on this? Reversing lights were not working so, Got a new rev light switch and attached to the loom. Ignition on and press the switch - still no lights! Will check feed tomorrow. Fuse is OK as it covers other things.... Any pointers welcome. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 29, 2008 Share Posted January 29, 2008 Could be worn linkage in the top of the box. I think the tab that pushes the switch wears or breaks. I had this on a 200tdi disco. Never did fix it till I had to change the box for an Ashcrofts one (mainshaft spline wear). Fine ever since! Quote Link to comment Share on other sites More sharing options...
DrRob Posted January 29, 2008 Author Share Posted January 29, 2008 Could be worn linkage in the top of the box. I think the tab that pushes the switch wears or breaks. I had this on a 200tdi disco. Never did fix it till I had to change the box for an Ashcrofts one (mainshaft spline wear). Fine ever since! Thanks but I'm further down the "road" than that. Reverse plunger assembly already off vehicle.... I'm bypassing that by manualling pushing the reverse light switch..... Quote Link to comment Share on other sites More sharing options...
disco tony Posted January 30, 2008 Share Posted January 30, 2008 check continuity of feed wire from switch to lamp. This wire runs under vehicle so is prone to damage Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted January 30, 2008 Share Posted January 30, 2008 sorry I missed that! Looks like its a case of finding the broken wire or bad earth then. Fuse and bulb OK? Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted January 30, 2008 Share Posted January 30, 2008 CAn't remember the type of switch. DOes it only have one spade connector? If so it needs to be earthed whn you are testing ( sorry if teaching granny to suck eggs) My '92 disco had a problem with the reversing lights flickering on all the time which was down to the wire being damaged over the top of the box. The reversing lights of that earthed through the switch. Maybe yours has broken completely somewhere? If yours are the same, with the ignition on, you can check to see if you have 12v at the lights, and work from there. Quote Link to comment Share on other sites More sharing options...
DrRob Posted January 30, 2008 Author Share Posted January 30, 2008 Might have sussed it...one bulb missing, one blown. Plunger was stuck in = rev lights would have been permanently on! Last owner must have removed the good bulb! Doh! Teach me to check basics first. Had to take gearbox cover off anyhow to fix the lack of reverse gate resistance... Thanks for all the pointers.... Quote Link to comment Share on other sites More sharing options...
bazza Posted February 12, 2008 Share Posted February 12, 2008 Might have sussed it...one bulb missing, one blown.Plunger was stuck in = rev lights would have been permanently on! Last owner must have removed the good bulb! Doh! Teach me to check basics first. Had to take gearbox cover off anyhow to fix the lack of reverse gate resistance... Thanks for all the pointers.... Bulbs!!! why didn't i think of that!!! Quote Link to comment Share on other sites More sharing options...
DrRob Posted February 12, 2008 Author Share Posted February 12, 2008 You live and learn Baz.... Quote Link to comment Share on other sites More sharing options...
