110_USA Posted March 2, 2008 Share Posted March 2, 2008 There is a small, short, metal tube on the top right hand corner of my fuel tank (right next to the fill hose) that has been capped off. It appears to be leaking from its base. Should I just remove the tube or try to patch it? What is it for anyway? A spare fuel tank connection? Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 2, 2008 Share Posted March 2, 2008 There should be two pipes - one is the filler pipe and the other is where air exits the tank as it fills with fuel. If the fuel goes in too quickly it'll 'glug' and blow back - spraying fuel back out of the filler neck. Les. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 2, 2008 Share Posted March 2, 2008 goes in too quickly it'll 'glug' and blow back - Les. I knew a girl like that once.... Quote Link to comment Share on other sites More sharing options...
western Posted March 2, 2008 Share Posted March 2, 2008 I knew a girl like that once.... Behave, Quote Link to comment Share on other sites More sharing options...
western Posted March 2, 2008 Share Posted March 2, 2008 There is a small, short, metal tube on the top right hand corner of my fuel tank (right next to the fill hose) that has been capped off. It appears to be leaking from its base. Should I just remove the tube or try to patch it? What is it for anyway? A spare fuel tank connection? Thanks The photo is my 110's new tank prior to fitting, I've marked the connections with their respective duties the short small diamete pipe adajacent to the filler pipe is the normall vent it should be connected to the filler top section attached to the body panel by a rubber fuel resistant hose. Quote Link to comment Share on other sites More sharing options...
110_USA Posted March 2, 2008 Author Share Posted March 2, 2008 Sorry I neglected to mention, The air relief is in place and working well, the other one is right next to it. Will try to post some pics today. Quote Link to comment Share on other sites More sharing options...
