Trevor Wright Posted March 9, 2008 Share Posted March 9, 2008 Does anyone know all the gear ratios on the current Puma Defender in High and Low ratio? Quote Link to comment Share on other sites More sharing options...
Mack Posted March 9, 2008 Share Posted March 9, 2008 Transmission GFT MT-82 six speed manual Full time four wheel drive Transmission (high/low) : 1 Overall Gearing (High/Low Range) 1st 5.443 23.334/62.988 2nd 2.839 12.171/32.854 3rd 1.721 7.378/19.916 4th 1.223 5.243/14.153 5th 1.000 4.287/11.572 6th 0.742 3.181/8.587 Reverse 4.935 21.156/57.109 Final drive ratio : 1 3.540 High range transfer box ratio 1.211 Low range transfer box ratio 3.269 Quote Link to comment Share on other sites More sharing options...
Trevor Wright Posted March 9, 2008 Author Share Posted March 9, 2008 Thanks Mack, I presume your info comes from the same place as the reply I received on another Forum: http://www.landyonline.co.za/specs/defender2007.htm which gives details of the drivetrain. The GFT MT-82 gearbox is a Getrag Ford Transmission unit similar to that used in the Ford Transit van. Manufacturing of the MT82 six-speed gearbox for Ford Motor Company takes place at the Halewood Transmission Plant. The table on the above page and as reproduced by Mack above shows all the ratio information. I see 5th is 1:1 and 6th is 0.742:1 and so I presume you could describe that as overdrive. Quote Link to comment Share on other sites More sharing options...
alantd Posted March 9, 2008 Share Posted March 9, 2008 Thanks Mack, I presume your info comes from the same place as the reply I received on another Forum:http://www.landyonline.co.za/specs/defender2007.htm which gives details of the drivetrain. The GFT MT-82 gearbox is a Getrag Ford Transmission unit similar to that used in the Ford Transit van. Manufacturing of the MT82 six-speed gearbox for Ford Motor Company takes place at the Halewood Transmission Plant. The table on the above page and as reproduced by Mack above shows all the ratio information. I see 5th is 1:1 and 6th is 0.742:1 and so I presume you could describe that as overdrive. I'm confused: When is an overdrive not an overdrive? I always assumed that an "overdrive" was a discrete addition to the transmission - like the Fairey one. The fact that the 6th gear runs at lower than 1:1 doesn't have any significance - its just a gear. Am I wrong? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 10, 2008 Share Posted March 10, 2008 Yes, "overdrive" can refer to any gears that are lower than 1:1 thus making the gearbox a speed increaser. http://en.wikipedia.org/wiki/Overdrive_(mechanics) Quote Link to comment Share on other sites More sharing options...
Top90 Posted March 10, 2008 Share Posted March 10, 2008 Yes, "overdrive" can refer to any gears that are lower than 1:1 thus making the gearbox a speed increaser.http://en.wikipedia.org/wiki/Overdrive_(mechanics) Well, you learn something new everyday. I thought an overdrive was an add to the transmission too. Quote Link to comment Share on other sites More sharing options...
alantd Posted March 10, 2008 Share Posted March 10, 2008 Yes, "overdrive" can refer to any gears that are lower than 1:1 thus making the gearbox a speed increaser.http://en.wikipedia.org/wiki/Overdrive_(mechanics) Hmm - seems a bit OTT. In that case my car has 4 underdrives, 1 drive and 1 overdrive - a gearbox by any other name Quote Link to comment Share on other sites More sharing options...
gemsbok Posted March 10, 2008 Share Posted March 10, 2008 Yes, "overdrive" can refer to any gears that are lower than 1:1 thus making the gearbox a speed increaser.http://en.wikipedia.org/wiki/Overdrive_(mechanics) Although the Wiki article makes that claim, the rest of the article is actually about units added to the gearbox; mostly manufactured by Laycock de Normanville (it mentions Fairey as well). That is what most people associate with the word of course - particularly those who travelled in older Volvos or other vehicles fitted with them. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 10, 2008 Share Posted March 10, 2008 Maybe it is a UK thing. Traditionally "overdrive" MEANS speed increaser. In the past, gearbox top gears were always 1:1. When they started building ones with less than 1:1, the were called gearboxes with overdrives...... Whether or not the overdrive is in a spearate gearbox or in the main gearbox matters not. http://www.merriam-webster.com/dictionary/overdrive Main Entry: over·drive Listen to the pronunciation of overdrive Pronunciation: \ˈō-vər-ˌdrīv\ Function: noun Date: 1926 1 : an automotive transmission gear that transmits to the drive shaft a speed greater than engine speed Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 10, 2008 Share Posted March 10, 2008 Adjectives and nouns An overdrive (noun) - a selectable device to raise the gearing over 1:1 (I know it works in the other gears too ) An overdrive gear (adjective) - describing a gear with a ratio of more than 1:1 My take on it Mo Quote Link to comment Share on other sites More sharing options...
alantd Posted March 10, 2008 Share Posted March 10, 2008 Up the pedant revolution! Quote Link to comment Share on other sites More sharing options...
