v8 wiring to tdi glow plugs
i have an isuzu td installed so most has already been changed but when converted from the v8 no glow plugs have ever been wired up its never needed them even when really frosty but now going to convert to a disco 200tdi which i assume will need them wired up how do i go about this and what will i need to get off the disco loom ?
you may not need them with the 200TDI (i dont on my disco or my 90 with a disco engine).
the easy way would be wire up a relay to a push butten then to the glow plugs.
may be possible to use the accessory position [with the ign/oil light light up] of the ignition switch to operate a Tdi type timer relay for the glowplugs.
