davec Posted March 13, 2008 Share Posted March 13, 2008 Hi Newby here i have a 95 disco 300tdi and 5th gear and reverse wont engage any body have any easy fixes or is this serious new box job Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 13, 2008 Share Posted March 13, 2008 5th and reverse are together in the extension to the box. I reckon you gearbox has had it. You will need a recon box from a good supplier. but others may have better ideas.... Quote Link to comment Share on other sites More sharing options...
cipx2 Posted March 13, 2008 Share Posted March 13, 2008 davec, can you describe the problem a little bit better? or maybe you can answer some questions: - does the lever move to the right enough to be able to engage 5th and reverse (does it have enough travel)? - from a stand still, engine running an clutch depressed, can you stick it in 5th? how about reverse? - same as above but with the engine stopped, can you engage the 2 gears? - if you can engage reverse with the engine stopped, keep the clutch pedal down and start the engine, can you reverse the vehicle? - if you somehow are able to engage reverse or the lever moves like it's engaging reverse, do you hear a click when you bring the lever back to neutral? How many miles/km does your Disco have? Quote Link to comment Share on other sites More sharing options...
paintman Posted March 15, 2008 Share Posted March 15, 2008 http://www.ashcroft-transmissions.co.uk This question is covered in the FAQ section. Not good news, the layshaft extension has probably sheared off so a new or rebuilt gearbox required. Quote Link to comment Share on other sites More sharing options...
pinkbeef Posted March 22, 2008 Share Posted March 22, 2008 I have a Disco 1 which had a problem engaging reverse, the disco 1 has the reverse on the far left. I also noticed the gear stick was very floppy, and would not return to the central position when I let go of it. The gear lever is held in the central position by a spring which is held in place by an 'L' shaped bracket, which had snapped and was lodged between the gear stick and the case preventing the gear lever from being pushed over to the far left. As you will need to remove the gear stick central counsel to remove the gearbox, I suggest you do this first and check to ensure the small 'L' shaped bracket is not broken and jamming the gear leaver. Quote Link to comment Share on other sites More sharing options...
RRX Posted March 22, 2008 Share Posted March 22, 2008 I have a Disco 1 which had a problem engaging reverse, the disco 1 has the reverse on the far left.I also noticed the gear stick was very floppy, and would not return to the central position when I let go of it. The gear lever is held in the central position by a spring which is held in place by an 'L' shaped bracket, which had snapped and was lodged between the gear stick and the case preventing the gear lever from being pushed over to the far left. As you will need to remove the gear stick central counsel to remove the gearbox, I suggest you do this first and check to ensure the small 'L' shaped bracket is not broken and jamming the gear leaver. Always worth checking but the 300tdi has the r380 with reverse on the right and down Quote Link to comment Share on other sites More sharing options...
