LEAFERS RULE!!! Posted March 16, 2008 Share Posted March 16, 2008 I have seen SERIES salisbury front axles for sale on ebay, has anybody had any experiance of thes axles? Would it be the cure of all my front axle shaft/diff mangling woes? Any comments greatfully received. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted March 16, 2008 Share Posted March 16, 2008 It will sort out the diff and maybe the shafts but not the UJ's, they become the weak link, break one and you mangle the shafts anyway. Plus you loose ground clearance. Grem Quote Link to comment Share on other sites More sharing options...
LEAFERS RULE!!! Posted March 16, 2008 Author Share Posted March 16, 2008 It will sort out the diff and maybe the shafts but not the UJ's, they become the weak link, break one and you mangle the shafts anyway. Plus you loose ground clearance.Grem Seen a salisbury that had been shaved at the the bottom to gain a bit back and as im running 35 inch wheels at the minute with possible 37s on the cards i would sacrifice a bit of underaxle clearance for piece of mind, its the actual legth of the diff nose that bothers me more than anything as i would have to shorten the prop. When you say uj do you mean on the prop or the shaft as these axles come off an armoured car that had the old rangie 4speed premanant gearbox so i assume it will have cv,s which i have been told are much stronger than the uj halfshfts? Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 16, 2008 Share Posted March 16, 2008 Have a look at the prop for a pre 1974 1ton, that had a Sailsbury front axle. Quote Link to comment Share on other sites More sharing options...
les Posted March 16, 2008 Share Posted March 16, 2008 Have a look at the prop for a pre 1974 1ton, that had a Sailsbury front axle. my 1970 1ton runs env axles front and rear my dad brought it brand new like it Quote Link to comment Share on other sites More sharing options...
Gremlin Posted March 17, 2008 Share Posted March 17, 2008 It should fit if you have a standard engine, yes the prop will have to be shorter. I was refering to the uj at the shaft but it seems you can assume correctly that the axle you found should have cv's due to the gearbox. CV's are the same as stage 1 v8's. Grem Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 17, 2008 Share Posted March 17, 2008 It'll be stronger but some front Salisbury parts are hard to find due to the rarity, and I'm not 100% convinced Land Rover have made much that stands up to 37's and abuse as stock - 101 axles spring to mind, Bathtub was running them before he went to Mogs. They're salisbury but different internals than Series / Defender ones, I think the UJ/CV (?) is much bigger and presumably that means other weaknesses were ironed out too. It could work, or it could be a lot of pain for very little gain. Have a search for "axle swap", most combinations have been covered on here. Quote Link to comment Share on other sites More sharing options...
minivin Posted March 17, 2008 Share Posted March 17, 2008 It'll be stronger but some front Salisbury parts are hard to find due to the rarity, and I'm not 100% convinced Land Rover have made much that stands up to 37's and abuse as stock - 101 axles spring to mind, Bathtub was running them before he went to Mogs. They're salisbury but different internals than Series / Defender ones, I think the UJ/CV (?) is much bigger and presumably that means other weaknesses were ironed out too.It could work, or it could be a lot of pain for very little gain. Have a search for "axle swap", most combinations have been covered on here. 101 axles are lower ratio as well, 5.57:1 rather than 4.7:1 or 3.54:1 Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 17, 2008 Share Posted March 17, 2008 my 1970 1ton runs env axles front and rear my dad brought it brand new like it The 1 ton had ENV, Salisbury and Rover axles at various times. My S3 parts book says pre 74 had Salisbury axles and gave a part number for the prop shaft. That's all I had to go by for the Salisbury part. Quote Link to comment Share on other sites More sharing options...
LEAFERS RULE!!! Posted March 17, 2008 Author Share Posted March 17, 2008 thanks for the info, im gonna have to have a good think about the axles may be better to puy toyota axles in and electric lockers i have a detroit locker uprated 24 spline shafts at the rear and they have never let me down but cant find anything to uprate the front 10 spliners what i have found is abroad and an arm n a leg! would be better off maybe saving up a bit more and getting a set of portals??? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 17, 2008 Share Posted March 17, 2008 101 axles are lower ratio as well, 5.57:1 rather than 4.7:1 or 3.54:1 True, but that's less of an issue running big tyres - mine is ~7:1 gearing and goes OK on 37's. Quote Link to comment Share on other sites More sharing options...
