russianfrog Posted April 2, 2008 Share Posted April 2, 2008 I still think of buying a handwinch for my Def 110. I don't want to install the full electric system on the bumper as I might use it very rarely. But I want something to get out of the mud when it happens... Depending of what is available around here, it will be a T-Max or Tirfor. There exist many versions of various strength. I know the Def 110 is about 2000 Kg of weight. What do you think, I should get definitely something that pulls more than 2T or with a 1.5T that will do the job? Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2008 Share Posted April 2, 2008 I have a Brano 1.6tonne hand winch it'll move my 110 easily, so go for a 1.6tonne as the minimum. Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted April 2, 2008 Share Posted April 2, 2008 Just be aware that when stuck in gloopy mud, it's quite possible for the power needed to unstick the truck to be well over the actual weight of the vehicle.....i have a 3200kg pull one..... but it is quite heavy!!! Quote Link to comment Share on other sites More sharing options...
AndyEvans Posted April 3, 2008 Share Posted April 3, 2008 I would personally get only a tifor. For that type of winch and would get the tu32 but that is quite expensive but withstands a lot of abuse. It has a pull capacity of 5 ton and lift of 3.5 ton. if you want a cheaper less heavy duty version you should look at the tu532. Quote Link to comment Share on other sites More sharing options...
JST Posted April 3, 2008 Share Posted April 3, 2008 i'd buy one i the 3-5T capability range Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 3, 2008 Share Posted April 3, 2008 Yep agree^^^^^ Get the tirfot T35. 5t pull 3t lift. Big heavy and reliable. We use them at work all the time. Quote Link to comment Share on other sites More sharing options...
