whoami Posted April 6, 2008 Share Posted April 6, 2008 Hi, how much benefit (if any) will I get from fitting something like this. http://www.cheviot4x4.com/shop/Products/Su...20Ball%20Joint/ Cheers Quote Link to comment Share on other sites More sharing options...
LR90 Posted April 6, 2008 Share Posted April 6, 2008 Sort of depends what else you have done and what's limiting you now? Quote Link to comment Share on other sites More sharing options...
whoami Posted April 6, 2008 Author Share Posted April 6, 2008 Sort of depends what else you have done and what's limiting you now? Truck has OME dampers and srings. suspension is pretty standard apart from that. What would you recommend? Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2008 Share Posted April 6, 2008 My 110 is on OME springs & dampers & still have the LR standard A frame joint fitted, it seems to be fine. Quote Link to comment Share on other sites More sharing options...
newclear Posted April 6, 2008 Share Posted April 6, 2008 That is indeed a lot of cash for a Ball joint.... . Could someone explain how a ball joint can be anything special? Surely a Land Rover ball joint is as good as that? Don't really even understand the Adjustable ones.... Probably as I only greenlane , doesn't really require anything overly extreme. Cheers Matt2 Quote Link to comment Share on other sites More sharing options...
western Posted April 6, 2008 Share Posted April 6, 2008 the adjustable version is so you can adjust for any wear in the joint. Quote Link to comment Share on other sites More sharing options...
