BFGoodrich MK2 the new MT
jules
<snip>
In the meantime, if you want 255 M/Ts the current BFG M/T is your only choice.
can you get the Maxxis 762 Big Horn in the UK ?
It has a more open tread than the BFG MT in that size. (255/85/16) It's slightly wider in section than the BFG (approx 10.3") and a touch wider in tread.
I've measured one up on a 6.5"130 HD rim at 2650mm circumference @ 31psi which = 844mm OD. That is pretty close to the claimed diameter of 33.3".
  • 6 months later...
