bombx3 Posted April 15, 2008 Share Posted April 15, 2008 when hot mines just above half and never moves,but the needle sits over the white line when stone cold.Is the needle to far up to begin with,Sorry to go on about little things but i think over the years im becoming a perfectionist ,,odd realy because im a brickie Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted April 15, 2008 Share Posted April 15, 2008 when hot mines just above half and never moves,but the needle sits over the white line when stone cold.Is the needle to far up to begin with,Sorry to go on about little things but i think over the years im becoming a perfectionist ,,odd realy because im a brickie Sounds like it is too far on to start with. Its a very simple job to change the gauge, and if i had a even the slightest doubt about mine then it would be changed. If ya post a wanted then i'm sure ya'll get one off someone for a few quid. It may even save ya a new engine one day Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 15, 2008 Share Posted April 15, 2008 change it for one like this http://www.demontweeks.co.uk/products/Prod...pcode=LMATIM034 the lr ones are useless Quote Link to comment Share on other sites More sharing options...
western Posted April 15, 2008 Share Posted April 15, 2008 firstly is your engine the Defender or Discovery 200Tdi ? the Defender gauge & Disco sender don't work very well together. if Defender 200Tdi-- then my temp gauge when at full working temp sits just to the left of the vertical position & very occasionally will increase to slightly right of vertical but not a full needle width. Quote Link to comment Share on other sites More sharing options...
bombx3 Posted April 15, 2008 Author Share Posted April 15, 2008 i have a defender 200tdi it sit one needle off the middle on the hot side but never moves up or down realy even when im pushing its Quote Link to comment Share on other sites More sharing options...
western Posted April 15, 2008 Share Posted April 15, 2008 maybe worth fitting a new sender PRC8593 is the correct item. Quote Link to comment Share on other sites More sharing options...
tonycougar Posted April 20, 2008 Share Posted April 20, 2008 maybe worth fitting a new sender PRC8593 is the correct item. Mine sits at the bottom when cold, but when it was hot it used to sit just over half unless it was towing during the summer. I have just fitted a new viscous unit and now it sits in between a quarter and half. I was towing with it today and it went up to half uphill. Slightly odd. Quote Link to comment Share on other sites More sharing options...
