Tris Cocks Posted April 15, 2008 Share Posted April 15, 2008 Whilst i was offroading at the weekend i heard a pop and my steering decided not to work. after getting it to a hard bit of ground by turning the wheels manually, i investigated and found that the shaft that is connected to the drop arm has dropped out, and i suspect that the shaft has broken. i have had a look on the tech archive and found the how to guide so know roughly how to change it. i have been offered a second hand steering box off a disco and am wondering if fit in my 90 (its a 300TDi by the way). also as i have power steering i am wondering if the power steering system is inside the steering box? and finally am i able to get a replacement shaft / service kit to repair it or does it have to be a replacement? Tris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 15, 2008 Share Posted April 15, 2008 I don't think you can buy the bits off the shelf - stripping these things is complicated anyway. The pump is seperate, so the box itself is the only thing that needs changing. Ralph is lurking - so he's about to tell you what will fit in it's place Never heard of the shaft snapping or coming out. I don't suppose you could post some pictures please? Les. Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 15, 2008 Author Share Posted April 15, 2008 I don't think you can buy the bits off the shelf - stripping these things is complicated anyway. The pump is seperate, so the box itself is the only thing that needs changing. Ralph is lurking - so he's about to tell you what will fit in it's place Never heard of the shaft snapping or coming out. I don't suppose you could post some pictures please? Les. thanks for that, i will get some pics of it on friday when i as home next and post them on here. Once i get it out i will be able to have a good look and tell you exactly what happened. Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted April 15, 2008 Share Posted April 15, 2008 Whilst i was offroading at the weekend i heard a pop and my steering decided not to work. after getting it to a hard bit of ground by turning the wheels manually, i investigated and found that the shaft that is connected to the drop arm has dropped out, and i suspect that the shaft has broken. i have had a look on the tech archive and found the how to guide so know roughly how to change it. i have been offered a second hand steering box off a disco and am wondering if fit in my 90 (its a 300TDi by the way). also as i have power steering i am wondering if the power steering system is inside the steering box? and finally am i able to get a replacement shaft / service kit to repair it or does it have to be a replacement?Tris Whos offered you the disco box Tris? Do you want me to have look tomorrow before you get back. Might save you a trip back to mailorder4x4 if you know its the box Ade Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 15, 2008 Author Share Posted April 15, 2008 If you could have a look ade it would be much appreciated. One of Ross's friends has one out of a disco and wants £40 for it. if it doesnt fit i can always see if there is still on on the 110 at combellacks or Joe said he has some over his place. Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 16, 2008 Author Share Posted April 16, 2008 so does anyone know if a disco box will fit into a 300TDi 90? Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 17, 2008 Author Share Posted April 17, 2008 I am also able to get hold of a steering box of an H reg 110 which has a 6 stud pattern on the top of the box whereas mine only has four studs. will this fit in the place of my box? Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted April 17, 2008 Share Posted April 17, 2008 I am also able to get hold of a steering box of an H reg 110 which has a 6 stud pattern on the top of the box whereas mine only has four studs. will this fit in the place of my box? Hi Tris, Just had a look at the disco box, the holes appear to be in the same position as my truck steering box. £40 sounds good. Would offer you mine but hink the discos sold. Ade Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 23, 2008 Author Share Posted April 23, 2008 i replaced the steering box at the weekend and managed to get hold of a disco steering box which i can confirm does the job perfectly, the only differnce was the drop arm. after i took the old steering box out and stripped it down i was able to find the problem, the shaft had sheared off, attached is some photos of the shaft stripped down on the bench. Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2008 Share Posted April 23, 2008 so does anyone know if a disco box will fit into a 300TDi 90? Same box on both vehicles, LR part STC8384 4 bolt Adwest lightweight power steering box.make sure you use the 90's original drop arm as the Discovery one is different. Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2008 Share Posted April 23, 2008 new shaft in 2002 was £167 plus vat. part number is RTC4398. Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 23, 2008 Author Share Posted April 23, 2008 i managed to get a steering box off a disco for £40 from the local scrapyard and it was swapped over within a couple of hours. £40 is alot better than £167 +VAT in my opinion Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2008 Share Posted April 23, 2008 i managed to get a steering box off a disco for £40 from the local scrapyard and it was swapped over within a couple of hours. £40 is alot better than £167 +VAT in my opinion I'll agree with that loads better for your wallet.glad you got it sorted quickly. Quote Link to comment Share on other sites More sharing options...
Scotian Posted April 23, 2008 Share Posted April 23, 2008 167 pounds for a new sector shaft!!!??? Thats crazy, How much does a new box cost from Landrover? Recon boxes are about the same price as that whole shaft!! Quote Link to comment Share on other sites More sharing options...
Reiny Posted April 24, 2008 Share Posted April 24, 2008 May I suggest that you keep the Discovery drop arm and use a Discovery drag link too. Discovery drop arms use ordinary ball joints, thus making ball-joint replacements in the future a doddle. You'll need to weld a bracket for the steering damper onto the drag link though. Quote Link to comment Share on other sites More sharing options...
