frogmeister Posted April 19, 2008 Share Posted April 19, 2008 I have just found out that i need to change my exhaust manifold gasket. How tricky is this? Will there be any other bits that need replacing as a result of doing this. eg other gaskets? also is the exhaust manifold secured with bolts or stud and nuts. The guy i've spoken to says it should be studs but I have bolts. Any advice would be gratefully received. Cheers Frogmeister Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 19, 2008 Share Posted April 19, 2008 Depends on what engine it is ! Mo Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 19, 2008 Share Posted April 19, 2008 I am a mind reader..... I reckon it is a Rolls-Royce Merlin. Gaskets are now made of unobtainium. Quote Link to comment Share on other sites More sharing options...
frogmeister Posted April 20, 2008 Author Share Posted April 20, 2008 oops, knew i'd forgotten something. It's a 97 defender 300 Tdi Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 20, 2008 Share Posted April 20, 2008 Then it's a quite straightforward job. Some of the bolt heads may be a bit tricky to get at but other than that there won't be anything to cause a crisis. The turbo oil lines can be a pain if you leave them connected. The normal 300 head has studs for the manifold, as you know and uses flanged M10 nuts that have been slightly squeezed so that the hole is not round (I assume this is for nut locking purposes). This may be why your gasket is leaking now since using bolts does away with this method of locking the nut although these gaskets are renown for leaking. HTH Mo Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 20, 2008 Share Posted April 20, 2008 Funny enough, they are renowned for leaking on the inlet side where the bolts are much smaller. It's the TD5 that suffers from blown exhaust gaskets normally caused by the teeny-weeny 8mm studs breaking, and that is normally caused by the single piece very long manifold warping. This can't happen with the 300Tdi as the manifold is in three pieces. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 20, 2008 Share Posted April 20, 2008 If you look at this thread - some of it will show you what you need to do to get at the gasket. http://forums.lr4x4.com/index.php?showtopic=8179 Les. Quote Link to comment Share on other sites More sharing options...
