rhydgte Posted April 28, 2008 Share Posted April 28, 2008 Hi all sorry if this is in the wrong place, have just bought a 1998 R 300TDi Disco, to prep for off-roading and to use as a general runaround! I am not completely new to the Land Rover world, as my dad has had numerous ones, and he currently owns two discovery's, all of which I've done a lot of work on over the years. Couple of niggling problems with mine I hope you guys can help out with.. Intermittent brake light flashing on dash Handbrake won't stay up sometimes Cheers Rhyd Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 28, 2008 Share Posted April 28, 2008 The light is probably low brake fluid warning? Do you mean the ratchet mechanism on the handbrake is not holding properly? Quote Link to comment Share on other sites More sharing options...
tuko Posted April 29, 2008 Share Posted April 29, 2008 "Intermittent brake light flashing on dash" is "low brake fluid warning" because of worn pads. Usually the fronts go first, so I'd replace those and see if it stops the flashing warning light. (we had the very same symptom with our Disco) Cheers, Todd. Quote Link to comment Share on other sites More sharing options...
rhydgte Posted April 29, 2008 Author Share Posted April 29, 2008 Do you mean the ratchet mechanism on the handbrake is not holding properly? Yes thats it! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 29, 2008 Share Posted April 29, 2008 New handbrake lever then I would think - not something I would wish to cut corners with! Quote Link to comment Share on other sites More sharing options...
old leafer Posted April 29, 2008 Share Posted April 29, 2008 Yes thats it! its allways work cleaning the rachet and blasting with wd40 i had the same prob and mine is fine now it had been greesed befor i got it and have set like concret Quote Link to comment Share on other sites More sharing options...
thebiglad Posted April 29, 2008 Share Posted April 29, 2008 Hi all sorry if this is in the wrong place, have just bought a 1998 R 300TDi Disco, to prep for off-roading and to use as a general runaround!I am not completely new to the Land Rover world, as my dad has had numerous ones, and he currently owns two discovery's, all of which I've done a lot of work on over the years. Couple of niggling problems with mine I hope you guys can help out with.. Intermittent brake light flashing on dash Handbrake won't stay up sometimes Cheers Rhyd I'm not 100% sure but isn't this brake light to which you refer, the same one that comes on when you put the handbrake on? The two problems may well be related. I'm pretty sure i've read something about Disco handbrakes missbehaving in this way. Quote Link to comment Share on other sites More sharing options...
python Posted April 29, 2008 Share Posted April 29, 2008 I'm not 100% sure but isn't this brake light to which you refer, the same one that comes on when you put the handbrake on? The two problems may well be related. I'm pretty sure i've read something about Disco handbrakes missbehaving in this way. i agree to this comment, i had a similar thing to this. was low fluid and sticky handbrake mechanisim. Quote Link to comment Share on other sites More sharing options...
rhydgte Posted April 30, 2008 Author Share Posted April 30, 2008 i agree to this comment, i had a similar thing to this. was low fluid and sticky handbrake mechanisim. Will get looking at this handbrake then, cheers! BTW Brake Fluid is fully topped up! Quote Link to comment Share on other sites More sharing options...
