Gremlin Posted December 16, 2005 Share Posted December 16, 2005 Hi all, I have a bit of a query. I just installed a certain parts software on an XP based machine, it runs for 4-5 mins then pops a window up saying error 113 and to contact helpdesk! I click ok and the program shuts down. I was running it on a 2000pro machine and it worked fine! Any clue, ideas or workaround this! Thanks Grem Quote Link to comment Share on other sites More sharing options...
siggy Posted December 16, 2005 Share Posted December 16, 2005 What manufacturer is it (the computer) I had no end of problems with the EPC on HP machines or is it microcat? Quote Link to comment Share on other sites More sharing options...
Gremlin Posted December 16, 2005 Author Share Posted December 16, 2005 What manufacturer is it (the computer) I had no end of problems with the EPC on HP machinesor is it microcat? Yep Microcat! Grem Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2005 Share Posted December 16, 2005 (edited) Try changing the computers date/time to 5th Jan then start microcat, it works for me on my XP Home desktop & XP Pro notebook Edited December 16, 2005 by western Quote Link to comment Share on other sites More sharing options...
siggy Posted December 16, 2005 Share Posted December 16, 2005 What Ralph Said Quote Link to comment Share on other sites More sharing options...
siggy Posted December 16, 2005 Share Posted December 16, 2005 And also on the CD should a bug fix program run that if you haven't already Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2005 Share Posted December 16, 2005 The Bug fix folder contains this info ----------------- Installation Information:- Change the date on your PC to Jan 5th 2005, close all open programmes, load the disc and it will autorun, select "Install Microcat" from the menu box, select your chosen language, select "Application and Data Installation", click next to install to default folder c:\MCLRE, select drive letter of your hard drive location. When installation has completed re-start the PC. Open the folder named "Bug Fix" located on the CD supplied and copy the mg16.dll file into C:\MCLRE folder on your PC, overwrite the file already in place, Repeat this process in the C:\WINDOWS\SYSTEM folder and C:\WINDOWS\SYSTEM32 folder on your PC as well. Now start Microcat. If any error messages appear click on them and restart program. Now start Microcat, when the programme opens click on "Start" button, select "ignore" when a message box opens, select "Administration", create a new user, select "Tax Tables" tab, enter value 0 in Code 0 then in 1 & 2 enter 17.5. Log in and open the programme, if you need to access prices you will need set the date to Jan 5th 2005 each time before you open the programme, once its open re-set back to the current date, the programme will continue to run. If you don't need prices then just open with the current date. hope that helps Quote Link to comment Share on other sites More sharing options...
tuko Posted December 16, 2005 Share Posted December 16, 2005 Just to add to what Ralph has written, if your using an older version of the mg16.dll with a newer or current version of Microcat, you have to roll back your system clock to the issue month or the following of the cd. (you get 60 days usage per cd) Todd. Quote Link to comment Share on other sites More sharing options...
Gremlin Posted December 19, 2005 Author Share Posted December 19, 2005 Ok i tried all of the above and i still keep getting the same error!! Damn XP!!! The microcat i have is till AUG 2004! i tried the date trick and it still gave me the error!! I also have the mg16.dll file in the right places, what else could be wrong? Grem Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2005 Share Posted December 19, 2005 I'd go for a re-install next. Quote Link to comment Share on other sites More sharing options...
siggy Posted December 19, 2005 Share Posted December 19, 2005 Try turning the comp date to Aug 04 and run it if error still occurs re-install Quote Link to comment Share on other sites More sharing options...
