trt1617 Posted May 9, 2008 Share Posted May 9, 2008 hi all started to fit a 2in lift kit to my 90 today and in the box are some what look like some recovery straps can anyone tell me what they are for and where they go? the kit came with dilocation cones as well and was wondering how bad the terrain would have to be for the springs to dislocate from the body? Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 10, 2008 Share Posted May 10, 2008 hi all started to fit a 2in lift kit to my 90 today and in the box are some what look like some recovery straps can anyone tell me what they are for and where they go? the kit came with dilocation cones as well and was wondering how bad the terrain would have to be for the springs to dislocate from the body? Any pics? These may be a form of check strap to use when jacking the vehicle up to change a tyre. Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 10, 2008 Share Posted May 10, 2008 hi all started to fit a 2in lift kit to my 90 today and in the box are some what look like some recovery straps can anyone tell me what they are for and where they go? They are probably check straps so that you can jack it up to change a tyre without having to jack it up too far. They normally bolt to chassis near shock mount and either hook on to axle or attach to mount that you bolt to the axle. the kit came with dilocation cones as well and was wondering how bad the terrain would have to be for the springs to dislocate from the body? Depends on if your kit came with +2" shocks or -2" shock mounts and how long your springs are. If it didn't come with shocks or lower mounts then no as your travel will be less than standard with the new springs. If it did it depends on how long yopur springs are. Most will dislocate though in this set up. Cheers Steve Quote Link to comment Share on other sites More sharing options...
trt1617 Posted May 10, 2008 Author Share Posted May 10, 2008 hello all the kit list says they are check straps just didnt konw whee to attach them to and i have driven my 90 up a concrete ramp on the passanger side and it made it to the top and didnt dislocate atall as far as i know the springs and shocks and both extended Quote Link to comment Share on other sites More sharing options...
