d-90 Posted May 14, 2008 Share Posted May 14, 2008 Hello, As the title says, what are the differences between Salisbury disc braked axles (hubs, stub axles, discs, calipers, etc)? I thought they were all the same, but today I found a Salisbury with the caliper support welded to the axle flange instead of the usual bolt in piece I was used to see... :blink: Any help on this? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 14, 2008 Share Posted May 14, 2008 later salisbury axles had the caliper mount welded on. not sure when LR started doing it that way,. Quote Link to comment Share on other sites More sharing options...
d-90 Posted May 14, 2008 Author Share Posted May 14, 2008 later salisbury axles had the caliper mount welded on. not sure when LR started doing it that way,. Do you know if stub axles, hubs, discs and calipers are the same or interchangeable? Thanks Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 15, 2008 Share Posted May 15, 2008 Do you know if stub axles, hubs, discs and calipers are the same or interchangeable? Thanks Yes, the stubs and hubs etc are interchangable between the (old) drum braked casings, and the disc braked (both with bolt on and cast caliper brackets) my old 300Tdi 110 (on a T plate) had bolt on brackets, my last Td5 110 (2001) had the cast type brackets. but all the other bits were the same (or at least, they were interchangable) Quote Link to comment Share on other sites More sharing options...
tiagoc Posted May 15, 2008 Share Posted May 15, 2008 Yes, the stubs and hubs etc are interchangable between the (old) drum braked casings, and the disc braked (both with bolt on and cast caliper brackets) Are they also interchangable between a drum braked 109 and a disc braked 110 (or other disc brakes, from other models)? Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 15, 2008 Share Posted May 15, 2008 Are they also interchangable between a drum braked 109 and a disc braked 110 (or other disc brakes, from other models)? I will be soon finding out, converting a leaf salisbury to disc using what will fit.......... i am trying, series stubs, 110/90 front hubs + flanges with discs, i will report back when everything will start to materialise together. Grem Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 16, 2008 Share Posted May 16, 2008 The series hubs and 110 ones should fit OK, as the end of the axle tube is the same. shoud be more or less a bolt on job to fit the disk brakes to the series axle... apart from the halfshaft... although you may find that the series shaft will fit into the 90/110 drive flange (as they're both 24spline) so it should work. Quote Link to comment Share on other sites More sharing options...
