V8 Freak Posted May 19, 2008 Share Posted May 19, 2008 I found a value on Rave of 25Nm or 18LB/ft. Apart from torqing things to FT settings, can anyone advise what they believe or can report from factual source what the bolts should be tightened to for an effective seal please. I have no water leaks but suspect I may be have an air leak between valley gasket and inlet manifold / cylinder heads. Tickover gone to pot but runs well over 1100 RPM. Neil Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 19, 2008 Share Posted May 19, 2008 Cats well and truly 'out of the bag' re my post above on torque settings Nige Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 19, 2008 Author Share Posted May 19, 2008 Cat.. Bag.. Where ! Neil Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 19, 2008 Share Posted May 19, 2008 I would only go 1/2 turn beyond the recommended torque for the inlet manifold. You are in danger of distorting mating faces/the gasket if you go beyond that. Of course - diesels don't do this.......... Les. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted May 19, 2008 Share Posted May 19, 2008 I think HfH might be refering to this :- Clicky Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 19, 2008 Author Share Posted May 19, 2008 That he is Pete..... And this.... (Beware Diseasel types.. V8 Porn... Nothing for you here...... Move along.....) Not ticking over well... Looks like I didn't tighten the valley gasket / inlet manifold quite enough. Chasing down an air leak... Tweaked the bolts a little tonight and it's improving so I'll get another valley gasket etc. and re-fit everything in a few weekends when back from a nice week away down towards BBC. (Don't tell him.. Our secret..) Neil Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 19, 2008 Share Posted May 19, 2008 How are you going to seal the diesel injectors in the holes? You would have to have adaptors made that will thread into the inlet manifold, and then bored to take the injectors. You could be clever and make the adaptors with twin holes - one for an injector, and the other for the glow plugs. Les Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 19, 2008 Author Share Posted May 19, 2008 Surely I could just dangle them off the exhaust Les and drag them along the road.. Make a nice jangly noise maybe ! Be more use as an ornament I guess anyways... Not doing much in your engine thus far, so can't believe they'll be any more use in mine ! Neil Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 19, 2008 Share Posted May 19, 2008 Christ. He'll be asking where the elastic band goes on it next Nige Quote Link to comment Share on other sites More sharing options...
Fatboy Posted May 20, 2008 Share Posted May 20, 2008 Are you using one of the composite vallety gaskets or the plain tin? I assume the composites have a little more "give" and effect a better seal, they also resist corrosion better. I also use a light spray of the aerosol Hylomar sealant on both sides... and on the old blocks I've worked on, its good practice to make sure all of the bolts actually run to the bottom of their threads and are not goo'ed (tech word ) up with silicon from some previous botch repair. Quote Link to comment Share on other sites More sharing options...
