Tee piece for fitting oil pressure sender
Hi All,
I've just acquired a VDO pressure sender which has a 3/8" NTP thread.
I got a Tee piece with the same thread but it doesn't fit, as the existing 200tdi pressure switch is not tapered.
Anyone know where I could get such a Tee piece, preferably online?
Cheers,
Thats cos you've got the wrong thread! 200tdi is M10x1 IIRC. M10x1 is so close to 1/8BSP that it'll screw in however.
You're best bet IMHO is to do away with the T piece and standard low pressure switch and replce it with the correct threaded VDO sender. VDO do some nice sender unit that incorporate a low pressure switch for your warning light aswell. This is what i run and hence dont need a T piece.
Jon
Having just bought the sender I don't really want to have to get another one.
I guess I could make a t piece by drilling and tapping a suitable piece with the correct thread.
Just to clarify, is the 200tdi pressure switch M10x1?
