V8 Spring lengths
dollythelw
I have a Milemarker on a lightweight mount with plasma so that probably isn't much use to you? I guess it will be a lot lighter than an 8274 with a steel cable on a full bumper.
However I currently have standard 90 front springs but with the ANR2938 isolators fitted top and bottom this gives about 0.6" lift which is about right for that weight. Can measure if required.
