defenderbender Posted May 27, 2008 Share Posted May 27, 2008 Just started her up on Sunday and she nows squeals horribly under anything but the gentlest acceleration. sounds like the belts but the noise isnt coming from the front, got the missus to rev it up with my head under the bonnet and is coming from the back of the engine bay. maybe around the turbo? tightened up all the air hoses etc WD40'd the belts at the front and its still screaming like a banshee. really really loud when I boot it. any ideas what it could be? Alex Quote Link to comment Share on other sites More sharing options...
Kev Baldwin Posted May 27, 2008 Share Posted May 27, 2008 A warped exhaust manifold (common on Td5) can sound just like a squealing belt. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 27, 2008 Share Posted May 27, 2008 Thrust bearing - does it stop when you press the clutch pedal? Spigot bearing will squeal as well - TD5's seem to go through them quite a bit. Les. Quote Link to comment Share on other sites More sharing options...
defenderbender Posted May 27, 2008 Author Share Posted May 27, 2008 sounds like it is the exhaust manifold thats warped, am going to inspect now. am i going to cause any further damage by driving it as I have a funeral tomorrow and its a good 2 1/2 hour drive. Quote Link to comment Share on other sites More sharing options...
defenderbender Posted May 27, 2008 Author Share Posted May 27, 2008 just been out to have a look, and there is a bolt missing off the first bit of the manifold, must be causing the noise, not that much soot that I can see tho. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 28, 2008 Share Posted May 28, 2008 Have it skimmed before you refit it, it should then last a week or two before warping again. LR were as mad as usual making a one-piece manifold of that length. Quote Link to comment Share on other sites More sharing options...
DaveSIIA Posted May 28, 2008 Share Posted May 28, 2008 I frequently had the same problem with the exhaust manifold on a chipped Td5 Defender. The longest lasting solution was to mill out all the webs between each cylinder run of the manifold and then check the head face was flat & true. The studs in the head were replaced by cap head bolts (M8x35 IIRC), except for the centre two (cylinder #3) - location for the gasket & manifold when assembling. I found the problem never really went away until cap head bolts were fitted. The vehicle was sold a year ago and it is still running in my final configuration and apparently hasn't given a problem since. Quote Link to comment Share on other sites More sharing options...
