Madcowz Posted May 27, 2008 Share Posted May 27, 2008 Just replaced a TR end while everything is apart and as I tighten up the nut, the shank rotates so the nut isn't tightening. What is the technique to stop this? thanks. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 27, 2008 Share Posted May 27, 2008 Apply pressure from underneath. I use either jack or prybar. Just have to see what works for you Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 27, 2008 Share Posted May 27, 2008 yup apply some (constant - don't belt it) force to the end to get the taper to bite. Quote Link to comment Share on other sites More sharing options...
Madcowz Posted May 27, 2008 Author Share Posted May 27, 2008 yup apply some (constant - don't belt it) force to the end to get the taper to bite. I'm confused now. The taper narrows at the bottom so I would have thought that pushing the TR end down would push it into the taper. Surely pushing it up would just loosen it? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 27, 2008 Share Posted May 27, 2008 other end! Quote Link to comment Share on other sites More sharing options...
western Posted May 27, 2008 Share Posted May 27, 2008 I usually give them a bit of persausion with my plastic mallet so it sits down in the taper better. Quote Link to comment Share on other sites More sharing options...
Madcowz Posted May 27, 2008 Author Share Posted May 27, 2008 Ok, so either tap it down with the 'recently stolen from the camping box' rubber mallet or use a scissor jack type thing to gently push it down allowing the taper to bite. Lovely, will try that tomorrow. Next question: why do the track rod ends have grease nipples but not the drag link? Was pleased with how easily the thread came out of the track rod. Last time I changed a TR end on the Clio it took days of heating the steering rod up with a blow torch and whacking it before it started to loosen. Made worse by the flats on the rod having rounded off. This one just unscrewed once the clamp was loosened. Brought a faint glimmer of a smile to my otherwise miserable oily face. Quote Link to comment Share on other sites More sharing options...
western Posted May 27, 2008 Share Posted May 27, 2008 you can get both with grease nipples, depending on the manufacturer. Quote Link to comment Share on other sites More sharing options...
Litch Posted May 28, 2008 Share Posted May 28, 2008 I usually remove the grease-nipple and use a G-clamp to get the taper to bite (it only needs a little pressure unless you have damaged the threads somehow). As already stated, presense of grease nipples is down to brand. Quote Link to comment Share on other sites More sharing options...
