Guest diesel_jim Posted May 29, 2008 Share Posted May 29, 2008 I'm trying to find the part numbers for the bolts that hold the gearbox to the engine on a Td5 defender. can't for the life of me find them in microcat. i can find the clutch/flywheel/rear shim plate thing, but no bolts shown, and on the R380 bellhousing page, again, no bolts shown. there are threaded holes into the back of the block on the engine, so they must just be plain bolts, but i can't find any info. anyone shed any light on it? cheeeers! Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted May 29, 2008 Share Posted May 29, 2008 Jim, try FB108171L , FB108111 , FB108701S. I think these are the Gearbox to Bell Housing bolts. Rod Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2008 Share Posted May 29, 2008 Not shown on the diagram but within the list of parts, I've noted size & quanity EPC to the rescue 1 Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 29, 2008 Share Posted May 29, 2008 Cheers chaps! have a virtual pint on me!! edited: I went into microcat, on the bellhousing page, and with "superwindow" it lists all the bits that you showed there Ralph, they just don't appear.... really handy that!! thanks again. Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted May 29, 2008 Share Posted May 29, 2008 Jim, just tried that in MicroCat, I too was unaware that the list contains parts not shown. Excellent . Rod Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2008 Share Posted May 29, 2008 Glad I could help & do a bit of payback for the help you've given on the speedo thread. Quote Link to comment Share on other sites More sharing options...
AndyEvans Posted May 29, 2008 Share Posted May 29, 2008 most engines i think are M10 threads in the bell housing iirc it wants to be about 25/30mm long or is for 200/300's Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 29, 2008 Share Posted May 29, 2008 All the bolts are 13mm head M10 except for the top one that holds the starter motor on, which is 15mm nut on a stud. Les. Quote Link to comment Share on other sites More sharing options...
