gruntus Posted May 31, 2008 Share Posted May 31, 2008 Hi Gents, First off this one is on topic! Ok the longest engine build in history is moving forward.... I took the oil spray jets off the bottom of the cylinders to let me hone the bores. On replacement I went to replace the large and small washers for the spray bolt only to see the small washer is too small to fit. On closer inspection I can see that the original washers are both copper "crush" washers. I was a bit surprised not to have correct quality replacement parts as the bottom end set is a good quality Elring set from BeerMat. So......... Can anyone beat Ralph to the mark and find the part numbers for both of the crush washers? (Sorry Ralph its all take and no give) Thanks in advance. Cheers Grant Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 31, 2008 Share Posted May 31, 2008 washers above the jets are AFU1879L washers below are AFU1887L Both are part of gasket kit STC363 Western Quote Link to comment Share on other sites More sharing options...
gruntus Posted May 31, 2008 Author Share Posted May 31, 2008 Thanks Gromit, Ralph must be sunbathing somewhere .....oops should be B) Cheers Grant Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 31, 2008 Share Posted May 31, 2008 I think Ralph is swotting up on 2 1/4 diesel big end bearing part numbers this weekend. Mo Quote Link to comment Share on other sites More sharing options...
western Posted June 1, 2008 Share Posted June 1, 2008 Ralph was on recovery duty on a rally with no internet access [in the middle of Epynt ranges] Cheers to Gromit for adding the correct info, I'm back home now so normal service will resume. Quote Link to comment Share on other sites More sharing options...
gruntus Posted June 2, 2008 Author Share Posted June 2, 2008 Normality resumes like the tides and gravity.... cheers G Quote Link to comment Share on other sites More sharing options...
gruntus Posted June 9, 2008 Author Share Posted June 9, 2008 Gents, As a quick update I recieved the parts from the LR dealership (using the numbers listed above) and the washers are indeed crush washers. Those in the bottom end gasket set I receeved are just plain copper washers. On the down side I managed to shear one of the oil jet bolts whilst torquing up New low value torque wrench and oil jet bolts ordered........ Cheers G Quote Link to comment Share on other sites More sharing options...
western Posted June 9, 2008 Share Posted June 9, 2008 you hamfisted gorilla Quote Link to comment Share on other sites More sharing options...
gruntus Posted June 10, 2008 Author Share Posted June 10, 2008 you hamfisted gorilla I have been called a Silverback in the past.... Quote Link to comment Share on other sites More sharing options...
