jules Posted June 1, 2008 Share Posted June 1, 2008 I know nothing about auto's and mine is possibly in need of the bands adjusting also chatting the previous owner today he also suggested that the art car stick shift cable may have stretched as it doesn't select that well. to get it into N from 1st you have to go a few mm into R for 1st to disengage and get N. The trouble is when you start 1st is fine but shift in to 2nd then its like a clutch slipping then it engages and your off 3rd is fine. it could be the cable and not the bands Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted June 1, 2008 Share Posted June 1, 2008 I did mine some years ago, I know the Haynes book of lies is maintaining it's reputation giving a figure high enough to trash the gearbox! On that occasion I telephoned Ashcroft, I believe I wrote the correct figure in the manual. I'll have a look in the morning. Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted June 2, 2008 Share Posted June 2, 2008 OK it's morning now. Kickdown, low and reverse band adjustment. Having removed the sump (drain oil, disconnect battery, chock wheels, wear support tights etc) the low and reverse adjusters are visible on the end of the actuators. The kickdown adjuster is on the left hand side of the gearbox (outside) above the kickdown mechanism. Adjustment for all three is the same, slacken locknut and loosen the adjuster screw. Tighten the adjuster screw to 10 lbf (NOT the 72 lbf recommended by Haynes!) then slacken by 1 1/4 turns, tighten locknut. Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted June 2, 2008 Share Posted June 2, 2008 The numbers in the Haynes book are correct. Or they are in my copy at any rate. However they are in lb F in not lf f ft! It's not even as simple as 1 lb f ft = 12 lb f in IIRC. Easy mistake to make, I have done it myself. Someplace I have the original Chrysler service manual for the 727 and the 828, it's about 5000 pages. Jules, the adjusters are square, not hex headed. I made a wee tool, cut one end of an old drum brake adjusting spanner and welded it to a socket. Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted June 2, 2008 Share Posted June 2, 2008 Well pointed out Mr Highway! Anyone got a torque wrench calibrated in lbf in? The actual conversion is 6 lbf ft so Ashcroft ar close enough. I must get some glasses! Quote Link to comment Share on other sites More sharing options...
jules Posted June 2, 2008 Author Share Posted June 2, 2008 Thanks for your help Paul and HS I will give it a bash tonight Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted June 2, 2008 Share Posted June 2, 2008 Anyone got a torque wrench calibrated in lbf in? Yup, picked on up at the MOD disposals place in Rosyth Dockyard (now sadly closed). Here's a truly fascinating site on the subject of torque wrenches, conversions etc. Torque Wrenches Quote Link to comment Share on other sites More sharing options...
Highway_Star Posted June 2, 2008 Share Posted June 2, 2008 I knew this was around someplace Here is the link to the factory manual. Be warned, it's 240Mb! It's hosted by a pal of mine, I lent him the manual years aog and he scanned it. Chrysler Torqflite Manual Quote Link to comment Share on other sites More sharing options...
Tobias Posted June 11, 2008 Share Posted June 11, 2008 Has it been deleted? "file not found" Quote Link to comment Share on other sites More sharing options...
paintman Posted June 11, 2008 Share Posted June 11, 2008 Picked up my lb/in torque wrench off ebay. Less than £30 all in & its accurate. Quote Link to comment Share on other sites More sharing options...
steve_d Posted June 11, 2008 Share Posted June 11, 2008 Here is a free download I have been using for years. It's a converter for loads of different things. http://joshmadison.com/article/convert-for-windows Including today's subject...Torque. Steve Quote Link to comment Share on other sites More sharing options...
