g90 Posted June 3, 2008 Share Posted June 3, 2008 My defender gives out a good blast of black smoke on start up, and i was wanting to check, and possibly adjust the injection timing. How is it done? I have done a search but couldnt find anything Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2008 Share Posted June 3, 2008 Normal at start up & right after, all 200 & 300Tdi's do it to some extent, if it doesn't clear quickly then something is no right. have a look in the tech archive index. Quote Link to comment Share on other sites More sharing options...
muzaz Posted June 3, 2008 Share Posted June 3, 2008 probably its not injection timing which is wrong, but the pump setting, there are quite a few threads on the subject, and some experts on this forum...unfortunately i'm not one of them Quote Link to comment Share on other sites More sharing options...
Ex Member Posted June 3, 2008 Share Posted June 3, 2008 Sounds normal. The timing is set via a pin into the injection pump through an access hole in the timing cover and another pin in the flywheel through the drain hole. You "can" use drill bits or get the proper timing pins. Best to read the workshop manual..... Quote Link to comment Share on other sites More sharing options...
