goaty Posted June 9, 2008 Share Posted June 9, 2008 Hi all, Can anyone tell me weather a disco LT77 would fit into my defender 90?? I currently am running a defender lt77 but it has a bit of a crumble and i have a disco lt77 sitting here spare. What work would i have to do to fit it?? if the casing is different then i guess the casing but do i need to go this far?? thanks in advance Quote Link to comment Share on other sites More sharing options...
tjolliffe Posted June 9, 2008 Share Posted June 9, 2008 Hi all,Can anyone tell me weather a disco LT77 would fit into my defender 90?? I currently am running a defender lt77 but it has a bit of a crumble and i have a disco lt77 sitting here spare. What work would i have to do to fit it?? if the casing is different then i guess the casing but do i need to go this far?? thanks in advance Wont fit sorry. You would have to end up changing the casing as the gear sticks sit in different places between the disco and defender and the defender uses 'long stick' where as the disco uses 'short stick'. Bit beyond a DIY mecahnic to change gearbox casings - best bet is to get your defender one reconditioned. Good luck! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 9, 2008 Share Posted June 9, 2008 Yup, it will fit fine if you don't mind the gearstick coming out through the middle of the seat box ! Unfortunately you can't just change the gearchange assy as the internals operated upon by the gearchange are different too. HTH Mo Quote Link to comment Share on other sites More sharing options...
goaty Posted June 10, 2008 Author Share Posted June 10, 2008 o well, dont mind changing casings over but if i have to satrt fiddlingmore i dont really fancy it. Guess my gearbox can soldier on for another year. cheers Quote Link to comment Share on other sites More sharing options...
