imspanners Posted December 24, 2005 Share Posted December 24, 2005 As I managed to break one of the rear shockers today.... (Bloomin speed humps - "I'm sure it's nothing to do with my off-roading, dear"....!) I may as well replace the set, so what's everybodys opinion on the shocker market? I want to try to keep the standard look of my Disco, so don't want to raise the height with a full lift kit, but may venture into dis-location territory. Is it worth going for +2" shocks with dis-location cones or go for standard height and get the Scorpion evolution kit at a later date?? Oh, and suppliers? Don't want much for Christmas do I??? Quote Link to comment Share on other sites More sharing options...
imspanners Posted December 28, 2005 Author Share Posted December 28, 2005 Seeing as nobody answered I went ahead and bought some Pro-comp ES9000 +2" from John Craddocks (£120 for 4) Having fitted them and only got an extra 3cm droop, I removed the rear anti-roll bar which gave me an extra 7cm droop, total=10cm.... Cheap fix, and I don't drive fast enough to warrant the roll bar anyway. The downside = I need re-location cones now as the rear springs come off their seats. B) I seem to have a problem with the front shocks: The bottom shocker thread sits very close to the axle body and if I tighten the nut too much, it causes the thread to touch the axle!! I'm going out tomorrow to get some additional washers, has any-one else had this problem? Quote Link to comment Share on other sites More sharing options...
LR90 Posted December 28, 2005 Share Posted December 28, 2005 I seem to have a problem with the front shocks:The bottom shocker thread sits very close to the axle body and if I tighten the nut too much, it causes the thread to touch the axle!! I'm going out tomorrow to get some additional washers, has any-one else had this problem? Yeh, just trim the pin down with a hacksaw. Quote Link to comment Share on other sites More sharing options...
imspanners Posted December 29, 2005 Author Share Posted December 29, 2005 Yeh, just trim the pin down with a hacksaw. At least I'm not the only one! Chopping's a bit drastic for me, so I'll stick with extra washers. Quote Link to comment Share on other sites More sharing options...
Dunc Posted December 29, 2005 Share Posted December 29, 2005 Oh, and suppliers? Got all mine from M&M 4x4 and Paddocks. Bearmach +2" springs and DeCarbon dampers. I've got dislocation (or should that actually be 'relocation') cones but haven't fitted them yet, just H/D spring mounts. Might be able to do you a deal on those in the New Year if i decide i don't need them. Quote Link to comment Share on other sites More sharing options...
chuggaman Posted December 29, 2005 Share Posted December 29, 2005 At least I'm not the only one! Chopping's a bit drastic for me, so I'll stick with extra washers. or fit some extra spacers make it bigger mike Quote Link to comment Share on other sites More sharing options...
imspanners Posted December 29, 2005 Author Share Posted December 29, 2005 Fitted an extra flat washer between the upper bush and spring seat. I said it was close, and the bush wasn't being compressed properly in the first pic: Quote Link to comment Share on other sites More sharing options...
Andy Posted December 30, 2005 Share Posted December 30, 2005 common problem - ask mr angle grinder to 'adjust' them for you Quote Link to comment Share on other sites More sharing options...
