wkw90 Posted June 11, 2008 Share Posted June 11, 2008 Would the temp sender from a 2.5 TD fit a 200TDI Paul Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2008 Share Posted June 11, 2008 No, fits in different position & IIRC is different size. 200Tdi needs PRC8593 & will work with your existing gauge. my 110 was a TD had a 200Tdi fitted nearly 14 years ago, temp gauge is still the TD item my 110 was built with, works fine. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 11, 2008 Share Posted June 11, 2008 Uncle Ralph, Is that a conversion sender then ? Not the standard 200 tdi sender ? Mo Quote Link to comment Share on other sites More sharing options...
wkw90 Posted June 11, 2008 Author Share Posted June 11, 2008 Cheers Ralph , would you happen to know the part number of a 200TDI gauge ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 11, 2008 Share Posted June 11, 2008 ... and the part number of a 2.5 TD gauge if you'd be so kind Mo Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2008 Share Posted June 11, 2008 The same gauge for both is PRC7311 at least that what mine is not a conversion sender just the standard 200Tdi unit, that's all it's listed against in EPC Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 11, 2008 Share Posted June 11, 2008 Ralph, is the Defender sender different to the Discovery/RR sender ? I don't think we had a PRC7311 did we Paul ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2008 Share Posted June 11, 2008 (edited) Yes, Disco 200Tdi uses PRC8001 or PRC9917 Green. RR 200Tdi uses AMR1712 Are you confused yet further on the temp gauge above it was upto chassis JA 916603 after it was AMR2070 From JA 916604 TO KA 928139 then AMR2631 From (V) KA 928140 To (V) WA 159806 this is the PRC7311 temp gauge. it has a large white block across nearly 3/4 of the gauge face with the last 1/4 being in red. Edited June 26, 2008 by western Quote Link to comment Share on other sites More sharing options...
wkw90 Posted June 11, 2008 Author Share Posted June 11, 2008 Ralph, is the Defender sender different to the Discovery/RR sender ?I don't think we had a PRC7311 did we Paul ? Mo I don't think we did .. Quote Link to comment Share on other sites More sharing options...
western Posted June 11, 2008 Share Posted June 11, 2008 the gauge above is my original unit, the current one has the same part number IIRC but a slightly different display. like this one in this instrument pack. Quote Link to comment Share on other sites More sharing options...
