Pete Attryde Posted June 12, 2008 Share Posted June 12, 2008 Whilst changing the rear springs on my Discovery the other evening I noticed that as the axle approaches maximum droop, the radius arm is hitting the bracket on the axle and limiting the travel. This happens with the shocks connected as I have 11" OME shocks, and Gwynn's challenge mounts, cranked radius arms and X-springs. Would I be correct in thinking that I can clearance the bracket on the axle to stop the radius arm hitting, and if so how much material is it safe to remove? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Escape Posted June 12, 2008 Share Posted June 12, 2008 Whilst changing the rear springs on my Discovery the other evening I noticed that as the axle approaches maximum droop, the radius arm is hitting the bracket on the axle and limiting the travel. This happens with the shocks connected as I have 11" OME shocks, and Gwynn's challenge mounts, cranked radius arms and X-springs. Would I be correct in thinking that I can clearance the bracket on the axle to stop the radius arm hitting, and if so how much material is it safe to remove? Thanks in advance. I think your problem might be caused by the axle tilting forward to much when drooping. Have you changed anything on your A-frame? If not, perhaps you should consider an adjustable balljoint, to make sure the axle doesn't tilt too much. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 12, 2008 Author Share Posted June 12, 2008 I am sure your correct however to get the casing to be in the correct position at full drop the diff pinion would be pointing up to much at normal ride height. I have seen arms with the bush mounting off set to presumably stop this happening, However I am skint at the moment so I don't want to have to buy new arms if I can just grind a bit out of the bracket. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted June 12, 2008 Share Posted June 12, 2008 I have ground out a small section of the bracket on the axle on my last two trucks without any problems. You will not need to take too much out- best to take a bit at a time and see how you get on. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 12, 2008 Author Share Posted June 12, 2008 Thanks for that Mr milemarker. I know what I shall be doing over the weekend. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 13, 2008 Share Posted June 13, 2008 Bring it over and get the die drinder on it! will be there sat am and sun pm as have family stuff to do... vwp order is on the bonnet! Mike PS watch your feet for some reason the 109 dumped the contents of its sump Quote Link to comment Share on other sites More sharing options...
landrover598 Posted June 13, 2008 Share Posted June 13, 2008 I took this much out. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 13, 2008 Author Share Posted June 13, 2008 Excellent, a picture makes it so much easier. Thanks Dave. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted June 13, 2008 Share Posted June 13, 2008 I have not taken as much as that out and my arms do not make contact- I suppose it depends on the kind of arms you are using- sorry I don't have any piccys of mine to post... Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 13, 2008 Author Share Posted June 13, 2008 I will probably go for the grind a bit out then try it method rather than just grinding a huge lump out, but having a picture to give me an idea of what I can get away with is handy. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 13, 2008 Share Posted June 13, 2008 Sorry to go O/T but do you have any more pictures of your brake like protectors Dave? Thanks Mark Quote Link to comment Share on other sites More sharing options...
