expat69 Posted June 12, 2008 Share Posted June 12, 2008 my 3bolt flange rear diff has blown up... If I put any 24sp diff with a 4 bolt flange, what propshsaft can I use ? (disco 200 ? RR? else?) I have a disco 300tdi auto ? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 12, 2008 Share Posted June 12, 2008 Buy a 4 bolt 24 spline diff and swap the flange over, or are you looking to swap the prop to get rid of the donut? The flanges are a straight swap if you have a similar aged diff. Later D1 V8s had a proper UJ propshaft on the back so one of those would be best. Quote Link to comment Share on other sites More sharing options...
expat69 Posted June 13, 2008 Author Share Posted June 13, 2008 Later D1 V8s had a proper UJ propshaft on the back so one of those would be best. all of them ? Mk1 and Mk2 ? auto and manual box? Quote Link to comment Share on other sites More sharing options...
muddy_muppet Posted June 13, 2008 Share Posted June 13, 2008 You can use a standard D1 200tDi prop (plenty about 2nd hand + a set of u/j's). Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 13, 2008 Share Posted June 13, 2008 all of them ? Mk1 and Mk2 ? auto and manual box? They are thin on the ground here but I know a 1997 model year 3.9 auto that definitely had 2 UJ's on the back shaft from the factory. Quote Link to comment Share on other sites More sharing options...
iceshj Posted June 18, 2008 Share Posted June 18, 2008 When I swapped mine to a 24 spline, I used a RR prop. Cheap and easy to get hold of. Regards Dave Quote Link to comment Share on other sites More sharing options...
