latchy Posted June 25, 2008 Share Posted June 25, 2008 hi all mr clever here has parked his discovery on his garden so it cant be towed off to replace head gasket . But while i was at it i thought i would change the timing belt removed everthing but now cant get the bottom pully bolt out tryed with the starter but no joy and i cant move it to use a garage with a air impact gun any idears lads Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 25, 2008 Share Posted June 25, 2008 You need one of these - if not to get the pulley bolt undone, but certainly to do it up to the correct, very high, torque. Quote Link to comment Share on other sites More sharing options...
Boro Posted June 25, 2008 Share Posted June 25, 2008 How much are those jim and where can i get one or through the main dealer the only source? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 25, 2008 Share Posted June 25, 2008 I thought Difflock did them but not sure Quote Link to comment Share on other sites More sharing options...
Boro Posted June 25, 2008 Share Posted June 25, 2008 They do but nearly £80 with vat and delivery hmmm i may see if i can make my own at that rate, i know a local machinist who would turn up the main piece for beer money Quote Link to comment Share on other sites More sharing options...
Jason2 Posted June 25, 2008 Share Posted June 25, 2008 Find your timing mark on your flywheel (large notch) through wadeing plug hole, kin big screw driver & second person to lock it. Rachet with a big tube on it, job done! Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 25, 2008 Share Posted June 25, 2008 If you give me a while I will send you the measurements of mine and then maybe you can make one. I have heard of someone making one out of a piece of pipe with four little pipes welded inside. The real thing is very strong, of course. But if you can get someone to turn you up one, maybe you could sell them cheaper than Difflock and make a killing. Just to hack you off, I bought mine for R80 which is only about five quid at today's exchange rates. Quote Link to comment Share on other sites More sharing options...
thebiglad Posted June 27, 2008 Share Posted June 27, 2008 And how much would postage be to Europe???? Quote Link to comment Share on other sites More sharing options...
drkwack Posted June 29, 2008 Share Posted June 29, 2008 hi all mr clever here has parked his discovery on his garden so it cant be towed off to replace head gasket . But while i was at it i thought i would change the timing belt removed everthing but now cant get the bottom pully bolt out tryed with the starter but no joy and i cant move it to use a garage with a air impact gun any idears lads Hi, put car into 5th gear big breaker bar and 27mm (I think) socket and grunt , worked on my brother in laws this weekend, when we changed his timing belt, then two stage tighten it back up when finished. Torque setting and a further 90 degrees, Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 1, 2008 Share Posted July 1, 2008 Yeah, great to put all that torque through a rather weak gearbox and drive train. And the 5th gear is the weakest. If you must do this I would pick 4th. Then you can only break the mainshaft. Quote Link to comment Share on other sites More sharing options...
