kellyv8 Posted June 28, 2008 Share Posted June 28, 2008 ive changed all the filters plugs leads cap rotor arm worked pefect done a day in france everything was ok until the end of the day then it started messing around ie get up to 2500revs and it wants to cut out,splutters, loses all power got to the ferry eventually when at other side drove home no probs until after 22miles it started doing it again ive also changed the airflow meter to no avail can anyone please shed any light on this as its got me stumped Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 28, 2008 Share Posted June 28, 2008 For a start change the coolant temperature sender (from passenger side of the inlet manifold), this is often a cause of what you describe - use a genuine one - there not expensive Then report back Nige Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted June 28, 2008 Author Share Posted June 28, 2008 done that no joy ,its doing it now as soon as it gets up to operating temp if you rev it up to 3000 it just backs right off to nothing and goes up and down the revs Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 28, 2008 Share Posted June 28, 2008 Then most prob AFM (Air flow meter) Check the diagnostic manual I shoved in the tech archive Nige Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted June 28, 2008 Author Share Posted June 28, 2008 Then most prob AFM (Air flow meter)Check the diagnostic manual I shoved in the tech archive Nige ive changed the afm already its a mystery looks like its gotta go to the big scrapyard in the sky is there any chance it would be the ecu Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 28, 2008 Share Posted June 28, 2008 Yes it could be, but often the ECU is blamed for all sorts of aliments none of which are the ECUs fault Remove the bunch of earths on the back of the passegner cyl head clean with emery paper and redo, earths can cause all sorts of EFI problems You reaaly then need to use the diagnostic manaul I have posted in the tech archive, and work your way through methodically Then report back Nige Quote Link to comment Share on other sites More sharing options...
kellyv8 Posted July 5, 2008 Author Share Posted July 5, 2008 now all sorted it was running 16% instead of 1% and a few vacum pipes were blocked Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted July 29, 2008 Share Posted July 29, 2008 it was running 16% instead of 1% [confused] 16% of what? I think I missed something here... [/confused] Quote Link to comment Share on other sites More sharing options...
