Graham Thomson Posted July 6, 2008 Share Posted July 6, 2008 Ok, the guys at Mud UK spent some time on the dashboard last week........a couple of pictures below present the story so far, the truck has to go back at the end of August to get the finishing bits done since the guys are tied up with Billing over the next two weeks. The first picture is a little bonus!! And the last picture is how it used to look!! Quote Link to comment Share on other sites More sharing options...
western Posted July 6, 2008 Share Posted July 6, 2008 certainly looks better than the before picture, whats the 2 gauges in the top pod ? Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted July 6, 2008 Author Share Posted July 6, 2008 The two that are there are getting binned - they will be replaced by oil press, oil temp and water temp. the binnacle is now speedo, rev counter, fuel, volts. There are also 3 12v socket in the front, one where the broken cigarrete lighter used to be and two on the top pod, and three 12v sockets in the rear cabin, at the end of the bench seats. Quote Link to comment Share on other sites More sharing options...
western Posted July 6, 2008 Share Posted July 6, 2008 OK about the existing pod gauges & with the other matching gauges will make it look a lot better too, hope it doesn't take to long to get it finished. Quote Link to comment Share on other sites More sharing options...
Big_John Posted July 7, 2008 Share Posted July 7, 2008 Have you still got access to the levers for opening the air flaps? I've often thought about building something similar, but can't decide what to do about opening the flaps. Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted July 7, 2008 Author Share Posted July 7, 2008 The vehicle is an air-con one. The flaps dont open..... Sorry, I know that's not much help. Quote Link to comment Share on other sites More sharing options...
Big_John Posted July 7, 2008 Share Posted July 7, 2008 Arh, I see....thanks anyway! Quote Link to comment Share on other sites More sharing options...
Ian Barrett Posted July 21, 2008 Share Posted July 21, 2008 Do you mind me asking about that aircon - just out of curiosity. I've not seen that before - but by coincidence I was talking to the guy at mud thingy at billing and he was telling me about an aircon that sat on the dash top. Does it work well and was it intended for use in this country or for export? Have you got the accelerator pedal rubber missing? If you have, try getting one for a series with the little tabs that bend over. They are about an inch too long but if you cut the extra rubber off and leave the metal inside to make another tab they are a lovely fit for a 90 Quote Link to comment Share on other sites More sharing options...
western Posted July 21, 2008 Share Posted July 21, 2008 all the pedal pads are intact Graham's air con set up is IIRC non functional as bits are missing, it was the original type of air con for 110's, never seen a 90 with that dash. Quote Link to comment Share on other sites More sharing options...
Graham Thomson Posted July 21, 2008 Author Share Posted July 21, 2008 Friday should see the work complete for the moment!!! Had to do yet another re-shuffle with the gauges.....but I'm having a cb radio installed too....more pictures soon! Quote Link to comment Share on other sites More sharing options...
wkw90 Posted July 22, 2008 Share Posted July 22, 2008 Looking good Quote Link to comment Share on other sites More sharing options...
