MuddyMachine Posted August 18, 2008 Share Posted August 18, 2008 Hi all, I seem to have lost my indicators, I have hazards though. I have checked the fuses, and have replaced the switch. Any ideas? Cheers Quote Link to comment Share on other sites More sharing options...
simonb Posted August 18, 2008 Share Posted August 18, 2008 Hi all,I seem to have lost my indicators, I have hazards though. I have checked the fuses, and have replaced the switch. Any ideas? Cheers Have you checked you actually have an ignition switched supply at the switch? Hazards work off the battery supply Quote Link to comment Share on other sites More sharing options...
MuddyMachine Posted August 18, 2008 Author Share Posted August 18, 2008 Have you checked you actually have an ignition switched supply at the switch? Hazards work off the battery supply Haven't checked, will look tomorrow cheers Quote Link to comment Share on other sites More sharing options...
oakesy Posted August 20, 2008 Share Posted August 20, 2008 Haven't checked, will look tomorrow cheers Is the relay still clicking on and off. Also remove your steering cowling and check to see if there a live feed. Quote Link to comment Share on other sites More sharing options...
MuddyMachine Posted August 20, 2008 Author Share Posted August 20, 2008 Is the relay still clicking on and off. Also remove your steering cowling and check to see if there a live feed. Every thing is connected, I chaged the hazard switch again and they now work. But the dash lights only work when indicating right Quote Link to comment Share on other sites More sharing options...
oakesy Posted August 20, 2008 Share Posted August 20, 2008 Every thing is connected, I chaged the hazard switch again and they now work.But the dash lights only work when indicating right Sound like a faulty wire on the downward connection . If the relay still sounds okay for turning left and right and when you visible see all your indicators outside working okay. Could be a sign your indicator switch unit is faulty . Do you have a multimeter to check with. Have they been working okay before you change the Hazard switch. Sometimes relays get worn out too. Quote Link to comment Share on other sites More sharing options...
MuddyMachine Posted August 21, 2008 Author Share Posted August 21, 2008 All sorted, a couple of bad earths and a broken wire. Cheers all Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 21, 2008 Share Posted August 21, 2008 The switches often give trouble. Quote Link to comment Share on other sites More sharing options...
